Author Topic: What New parts would you advise  (Read 2017 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 06 February 2014, 12:11 »
I am having a new Beachbuggy Turbo k250 fitted, with a Badger5 ported manifold and an R-Tech supersize TIP. I am going to get a new manifold and downpipe gaskets too, but what else would you advise I get for this. i.e. new bolts ect. Thanks
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline golfyste
  • Project track car
Re: What New parts would you advise
« Reply #1 on: 06 February 2014, 12:53 »
New manifold nuts, banjo washers, and possibly new studs and bits for the turbo, turbo-manifold gasket  :cool:
« Reply #2 on: 06 February 2014, 16:56 »
Thanks. Are all those parts available from TPS?
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 06 February 2014, 17:56 »
Yep should be. I would invest £60 more and get that performance inlet manifold gasket. Its ment to stop the heat going from the engine to the inlet so keeps temps lower. Think its called power gasket by new south performance. If you have an agu engine code then you have the large port if any other then its small port
http://www.awesomegti.com/catalogsearch/result/?q=power+gasket
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #4 on: 06 February 2014, 19:47 »
Sorry, but I am a bit confused. Are you suggesting getting another gasket for the inlet manifold that is on the front of the engine? As I am only having the other manifold ported which the turbo goes on. Are there any performance gaskets for the manifold which I am getting ported?
Offline markgti1.8t
« Reply #5 on: 06 February 2014, 20:50 »
i have heard that there's coz problems and not worth it just get wmi its a lot better
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
« Reply #6 on: 06 February 2014, 21:08 »
Yeah, I just found a thread about those gaskets and apparently they are not that good because there have been reports of them cracking. In the same thread there was a mention of someone on MK4 forums that made some better ones, which some of the members from here did a group buy of.
