Author Topic: wheel offset question  (Read 4548 times)
Offline Hongkongphooey
« on: 01 February 2014, 22:09 »
Will a BBS 16" split rim with an offset of ET51 fit directly on my standard MK3 GTi without any significant issues?
I noticed that the 16" Anni rims had an offset of ET43
Ta
Offline itavaltalainen
Re: wheel offset question
« Reply #1 on: 02 February 2014, 13:42 »
here's a calculator that will show the difference (in german but does not really require much to work it out :) )
http://www.vwtyp17.de/Berichte/et/index1.htm
Offline hobbiniho
« Reply #2 on: 02 February 2014, 16:25 »
or you could use this one http://www.tire-size-calculator.info/
« Reply #3 on: 02 February 2014, 17:14 »
Your going to need 10mm spacers or they will hit the shocks.
« Reply #4 on: 03 February 2014, 07:36 »
Thanks lads, think I'll hold out for a set of the OEM BBS 16" wheels fitted to the anni or maybe even a set of 15" pepperpots, think they'd look good on a black GTi....
Don't want to go crazy on price as plan to fit a new full set of rubber, 2 on mine were manufactured in 2000! Better get them off quick!
« Reply #5 on: 05 February 2014, 08:56 »
Is there any good reason not to run a set of 15" BBS wheels with a slightly different tyre size to that recommended for the MK3 GTi?
Recco is 205/50/r15
I've been offered a set with:
195/55/r15 (Polo spec)
Mine has standard suspension
My instinct says I shouldn't but when I put it in the tyre calculator it shows that the rolling radius is only 1.7% different.....
I can't imagine an extra 5mm will look radically different either?
Help appreciated
Offline tweed
« Reply #6 on: 05 February 2014, 10:19 »
I once used up some tyres in the same 195 55 15 size on my mk3 16v. I didnt notice any difference in performance!!
But are these wheels from a polo? Correct me if im wrong but they are narrow. 6/6.5" wide? I wouldn't recommend that!
You at least want 7" wide. 8" being very good to fit a wider (more grip) tyre.
« Reply #7 on: 05 February 2014, 11:26 »
Tweed, PM sent!
« Reply #8 on: 05 February 2014, 13:57 »
6.5 x 15 will be fine, I used a set once as winters on my 8v.
195/55 tyres will affect the gearing however.
« Reply #9 on: 05 February 2014, 17:09 »
Wayne....when you say it will affect the gearing can you be more specific please?
Ta
