Author Topic: Fuel pump ?  (Read 5176 times)
Offline Gary#turbo
  • 100%boostaddict http://www.golfgtiforum.co.uk/inde
Re: Fuel pump ?
« Reply #20 on: 11 January 2014, 22:43 »
Okay that's good lol
U
I wud like to replace the pump tho cuz it's dun like 104k n Probs not bin replaced
U think I buy a new pump or the cupra r 1 4 £40 ?
if your going for a new pump then get the walbro its £75 on ebay. the oem pump new would be around £150-£200 I think. As for the cupra pump it might have a lot done and could break. If I was you I would keep using your original and if it gives up then upgrade. 104k on the original is not a lot.
Just to check
Is this the once your on about
Offline davidgtrr34
Re: Fuel pump ?
« Reply #21 on: 11 January 2014, 22:59 »
what ya mean :huh:
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Gary#turbo
Re: Fuel pump ?
« Reply #22 on: 12 January 2014, 00:00 »
Offline davidgtrr34
Offline Gary#turbo
Re: Fuel pump ?
« Reply #24 on: 12 January 2014, 00:44 »
Thanks mate I got it  :smiley:
Offline mattyfairbro240579
  • Nearly There With My 2.1 Stroker Build
Re: Fuel pump ?
« Reply #25 on: 15 January 2014, 02:41 »
I'm started to gather my parts 4 stage 2 map at r tech
In their list of things to do they said to geta new fuel pump
Can anybody tell me if they have a cupra r fuel pump and is it a str8 fit
Also what injectors do I get and wer from
Thanks
 :smiley: :smiley:
Hi there buddy, Ive had a cupra r fuel pump fitted for well over 6 months now, I'm running 313bhp and 341lbt done by Mr Nic at R Tech and it runs like a dream  :grin: was getting fuel starvation on the standard pump !!!
Took me less than 10 minutes to fit, make sure you buy a new gasket seal for the pump don't use your old one mate and there dirt cheap to buy
2000 1.8T R Tech remap - 310 bhp/321 lb;ft : Decat, stainless 2.5" exhaust, front mount intercooler, KO4 :  S2000 airfilter, Relentless manifold, Badger5 TIP, Saab red injectors, VR6 MAF housing, Forge 007p & Actuator, JK coilovers, Fully polybushed, Vibra Technics engine mounts, ECS Dogbone Mount, Cupra R fuel pump, TT subframe, Porsche 996 Calipers, HELL Lines, Custom 'J' Hook OE R32 Discs, Quaife ATB LSD,  Spec Stage 3+ Clutch & flywheel, WaterMeth, Rear ARB, AEM Data
Offline Gary#turbo
Re: Fuel pump ?
« Reply #26 on: 15 January 2014, 18:10 »
I don't no what to do bcuz iv bin offered 1 4 £40 but it's not gonna work as good as a new 1 is it
It been 2nd hand is putting me off
Wer I can buy a walbro for £70 brand new
Offline rockmonkey69
Re: Fuel pump ?
« Reply #27 on: 15 January 2014, 22:32 »
also if your going for high fuel pressure eg 5bar+ then the cupra pump will break
4 bar is overkill on most so 5 will be useless  :wink:
true 3bar is sound on a good map but then again I got around 210bhp with only 5bar fuel pressure and 18psi boost
Is this a joke??! This definitely made my day. I can always trust the forum to provide entertainment!
Seriously though just put the car back to standard.
Offline Chris.
Re: Fuel pump ?
« Reply #28 on: 16 January 2014, 04:13 »
Depends what engine code he has as to whether maf + injectors are suitable for 250bhp.... AGU will top out at 235bhp for both.
Look at the Sytec P3031 pump, capable of 7bar its a fit and forget pump and seems to be very very popular with those who love to tune at the minute.
Sure you need to have FPR psi value + the boost pressure for the pump to stand up...so in most cases....the fuel pump sees over 4bar?  Could be wrong on that tho.   Have a read into fuel pressure and boost.
Click For Build Thread
Re: Fuel pump ?
« Reply #29 on: 16 January 2014, 05:18 »
Only he's talking about static fuel pressures, 3 bar being mentioned as "sound on a good map". He's running 5 bar static fuel pressure so in most cases the pump is sees over 6 bars? Could be wrong on that though. Have a read into the previous post.
