Author Topic: Fuel pump ?  (Read 5177 times)
Offline Gary#turbo
  • 100%boostaddict http://www.golfgtiforum.co.uk/inde
Re: Fuel pump ?
« Reply #10 on: 11 January 2014, 21:46 »
I'm only going to a stage 2 map so it's guna be 250bhp tops 4 me  :smiley:
Plus what does 5 bar mean on fuel pressure?
standard fuel pressure is 3bar on 150 and 180bhp engines and 4bar on the 225bhp engines
but anything higher than 4bar will put a lot of pressure on the standard fuel pump and injectors and may lead to them failing
So would u say the cupra r pump will be to much 4 a stage 2 map ?
What injectors do u recommend 4 stage 2
Offline davidgtrr34
Re: Fuel pump ?
« Reply #11 on: 11 January 2014, 21:49 »
your standard pump and injectors are good for 250bhp with no problems
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Gary#turbo
Re: Fuel pump ?
« Reply #12 on: 11 January 2014, 22:03 »
Okay that's good lol
U
I wud like to replace the pump tho cuz it's dun like 104k n Probs not bin replaced
U think I buy a new pump or the cupra r 1 4 £40 ?
Offline davidgtrr34
Re: Fuel pump ?
« Reply #13 on: 11 January 2014, 22:15 »
U
if your going for a new pump then get the walbro its £75 on ebay. the oem pump new would be around £150-£200 I think. As for the cupra pump it might have a lot done and could break. If I was you I would keep using your original and if it gives up then upgrade. 104k on the original is not a lot.
Offline barrym381
Re: Fuel pump ?
« Reply #14 on: 11 January 2014, 22:18 »
U
i have seen an s3 pump being weak after 40k  :wink:
Offline davidgtrr34
Re: Fuel pump ?
« Reply #15 on: 11 January 2014, 22:20 »
U
ive seen them go before 10k and ive seen them last to over 4 :smiley:00k
Offline barrym381
Re: Fuel pump ?
« Reply #16 on: 11 January 2014, 22:23 »
U
400k thats just taking the piss now  :whistle:
Offline davidgtrr34
Re: Fuel pump ?
« Reply #17 on: 11 January 2014, 22:27 »
diesel corolla 2005 still going strong :grin:
Offline barrym381
Re: Fuel pump ?
« Reply #18 on: 11 January 2014, 22:31 »
not exactly the same pump is it  :laugh:
Offline Gary#turbo
Re: Fuel pump ?
« Reply #19 on: 11 January 2014, 22:36 »
Okay then il probably leave the cupra pump and just upgrade when needed , just thought I'd do it as that's 1 of the things to replace on the r tech guide on stage 2 lol
But thanks guys 4 all your help
