Author Topic: Fuel pump ?  (Read 5179 times)
Offline Gary#turbo
  • 100%boostaddict http://www.golfgtiforum.co.uk/inde
Fuel pump ?
« on: 11 January 2014, 20:30 »
I'm started to gather my parts 4 stage 2 map at r tech
In their list of things to do they said to geta new fuel pump
Can anybody tell me if they have a cupra r fuel pump and is it a str8 fit
Also what injectors do I get and wer from
Thanks
 :smiley: :smiley:
Offline davidgtrr34
Re: Fuel pump ?
« Reply #1 on: 11 January 2014, 20:42 »
get the walbro 255 pump. its very good a not that dear
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Gary#turbo
Re: Fuel pump ?
« Reply #2 on: 11 January 2014, 20:49 »
Well iv had the option on either but there 2 nd hand
Iv bin offered the cupra 1 4 £40 as it's someone breaking there golf
Offline davidgtrr34
Re: Fuel pump ?
« Reply #3 on: 11 January 2014, 20:55 »
if your going over 300bhp then buy the walbro but if not then the cupra pump is plenty and £40 is not a bad price
Offline barrym381
Re: Fuel pump ?
« Reply #4 on: 11 January 2014, 21:04 »
buy the pump new then you know it should work  :smiley:
Offline davidgtrr34
Re: Fuel pump ?
« Reply #5 on: 11 January 2014, 21:07 »
also if your going for high fuel pressure eg 5bar+ then the cupra pump will break
Offline barrym381
Re: Fuel pump ?
« Reply #6 on: 11 January 2014, 21:14 »
4 bar is overkill on most so 5 will be useless  :wink:
Offline davidgtrr34
Re: Fuel pump ?
« Reply #7 on: 11 January 2014, 21:22 »
true 3bar is sound on a good map but then again I got around 210bhp with only 5bar fuel pressure and 18psi boost
Offline Gary#turbo
Re: Fuel pump ?
« Reply #8 on: 11 January 2014, 21:22 »
I'm only going to a stage 2 map so it's guna be 250bhp tops 4 me  :smiley:
Plus what does 5 bar mean on fuel pressure?
Offline davidgtrr34
Re: Fuel pump ?
« Reply #9 on: 11 January 2014, 21:26 »
standard fuel pressure is 3bar on 150 and 180bhp engines and 4bar on the 225bhp engines
but anything higher than 4bar will put a lot of pressure on the standard fuel pump and injectors and may lead to them failing
