Author Topic: dump valve question  (Read 3409 times)
Offline viperjsy
dump valve question
« on: 09 January 2014, 13:16 »
hi dose the dump valve supposed to stay open on idel and make a ticking sound the car is a golf gti mk4 agu 1.8t but when I rev the car the dump valve closes and dumps  excuse the fan belt slip
« Last Edit: 09 January 2014, 15:39 by viperjsy »
Offline viperjsy
Re: dump valve question
« Reply #1 on: 09 January 2014, 15:37 »
sorry hit wrong button
Offline mcgee9t2
« Reply #2 on: 09 January 2014, 15:44 »
Can't veiw the video on my phone. But sure the ticking isn't the charcole canister?
Offline viperjsy
« Reply #3 on: 09 January 2014, 16:04 »
 I can feel the vibration on the dump valve where is the charcole canister located please can u post a pic were it is please
is it just in front of the coolent bottle a black square canester
« Last Edit: 09 January 2014, 16:06 by viperjsy »
Offline AD1.8T
« Reply #4 on: 09 January 2014, 16:56 »
Thats the one mate
Offline Kev13
« Reply #5 on: 09 January 2014, 17:19 »
will stay open on idle till rev it sound sounds bit like the charcole canister
Offline navmk4gti
« Reply #6 on: 09 January 2014, 18:01 »
Take it off its not going to help the running of the car mate. Get a forge 007 or 008. And no it should be closed on idle.
Offline viperjsy
« Reply #7 on: 09 January 2014, 20:36 »
will do when I can afford a new one
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #8 on: 10 January 2014, 08:38 »
Nothing wrong with that dump valve (Forge Split-r) I've been running it on my AGU for years now and never had an issue. Make sure the tension is set correctly on it, good starting point is to tighten it fully then loosen it by 3 full turns and see how it goes.
If you have the blanking plug to make it fully recirculating try that as well.
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline navmk4gti
« Reply #9 on: 10 January 2014, 09:05 »
Yes you wont have no engine managment light or anything but it will not boost as well as with a 007 or the new 008 forge recirculating valve.. i know this as i had forge split-r for year on my agu and after fitting a boost gauge i tested both and the 007p held boost better :wink:
