Author Topic: dump valve question  (Read 3438 times)
Offline dom
  • Back in a Mk4
Re: dump valve question
« Reply #10 on: 10 January 2014, 09:37 »
To be honest, I'd rather run a standard d/v than a split-r valve.
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #11 on: 10 January 2014, 15:29 »
I fitted a boost gauge on mine for the reason I was a bit suspect of all the bad press the split-r gets but mine boosts fine and holds with no leaks or drops in pressure, so I'm a fan.......... the only one :grin:
Mine is set to fully recirculate though haven't tried with the atmospheric set up.
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline navmk4gti
« Reply #12 on: 10 January 2014, 15:31 »
So your basically running it as a 007p  :grin:
Offline Perryd84
« Reply #13 on: 10 January 2014, 15:35 »
So I am :grin:
Offline viperjsy
vacume pipe to dump valve
« Reply #14 on: 10 January 2014, 16:22 »
hi the vacuum  pipe is continualy on so the dump valve is open on idel whet controles the vacuum  is it the n75 valve  thank you
and were about is the n75 valve located please a pic would be apreasiated
« Last Edit: 10 January 2014, 16:26 by viperjsy »
Offline dom
  • Back in a Mk4
« Reply #15 on: 10 January 2014, 16:34 »
I've merged your two threads together, you had 5 threads on the first page of this board and 2 of them were related. Only start a new thread if it's a completely new topic.
Offline viperjsy
« Reply #16 on: 10 January 2014, 16:36 »
sorry
Offline viperjsy
« Reply #17 on: 10 January 2014, 17:02 »
Offline Nino
  • Insta - F6UGA
« Reply #18 on: 11 January 2014, 11:21 »
as long as its an OEM valve it will work, saying that im sure I have a spare somewhere....
Current - MK6 GTi Edition 35 - Candy White - 3 door.
