Author Topic: Damp windscreen :/  (Read 8559 times)
Offline Mattyj
Damp windscreen :/
« on: 21 December 2013, 16:48 »
Hi this only happens in the morning noteablely in the recent coldish weather nothing appears damp in the car causing condensation and it is water not grease as previously mentioned it has a sunroof any ideas?
Offline Snoopy
  • Moderator
  • Geoff.
Re: Damp windscreen :/
« Reply #1 on: 21 December 2013, 17:24 »
Check the carpets arnt wet.
Door seals dont leak when pressure wash.
Check drain holes for the sunroof
Check drain for scuttle panel (empty bucket of water on windscreen should come out under car behind front wheel very quickly)
Check boot floor not wet as rear lights can leak.
Check rear washer works and iant emptying inside the car.
« Last Edit: 21 December 2013, 17:25 by Snoopy »
Current Garage:
35+ years of GTI ownership.
Offline Mattyj
« Reply #2 on: 21 December 2013, 17:48 »
Sense mate cheers had a leak in my fabia but the screen was soaking and i mean soaking this is damp but doesn't clear instantly my a/c isn't cold could that be something?
Offline barrym381
« Reply #3 on: 21 December 2013, 18:22 »
Offline Mattyj
« Reply #4 on: 21 December 2013, 19:06 »
Yea could do mate but if leaking somewhere rather sort it tbh
Offline Candy Man
« Reply #5 on: 21 December 2013, 20:23 »
Ive had exact same issues with condensation on windscreen,
I changed the cars pollen filter and cars windscreen has
Been dry ever since, old filter was a bit damp, i think
This has been source of condensation in the car, maybe
Check yours out m8, seems to have sorted mine, so far so
Good :)
Offline Mattyj
« Reply #6 on: 21 December 2013, 20:31 »
Cheers mate only changed this recentlyish tho :( will check it tho worth a look
Offline Chris.
« Reply #7 on: 22 December 2013, 03:31 »
might have been fitted incorrectly?
Click For Build Thread
Offline Raffe
« Reply #8 on: 22 December 2013, 07:18 »
Are you using your a/c this time of year?
My Leon would condensate through the winter when left if I had been using the a/c, turn it off and the problem never came back.
Was common problem from reading the forums.
Offline Snooze
« Reply #9 on: 22 December 2013, 08:49 »
I've got the same problem. AC off but past week or so it's steamed up like a scene from titanic every morning. Only recently had it serviced too. Swear it wasn't this bad last winter. My mk5 gti did the same, but not as bad.
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
