Author Topic: Damp windscreen :/  (Read 8563 times)
Offline Mattyj
Re: Damp windscreen :/
« Reply #10 on: 22 December 2013, 09:54 »
Well this is the first winter i've owned the car my fabia had a leak my sisters mk5 had a leak no i dnt use a/c this time of year it turns itself on when i hit the max demist button
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #11 on: 22 December 2013, 10:25 »
might have been fitted incorrectly?
Its inside the cabin on the mk6 not in the scuttle panel like the mk4 or older VWs.
Current Garage:
35+ years of GTI ownership.
Offline Poached
« Reply #12 on: 22 December 2013, 20:50 »
Had this problem in the MK5 and MK6 to a lesser extent. Changed/checked a number of items mentioned above and it didn't seem to make a significant difference.
The only thing that appeared to reduce the problem was minimising the temperature difference between the cars interior temperature and outside when it was parked up overnight.
Offline Mattyj
« Reply #13 on: 22 December 2013, 21:14 »
I suspected this with my fabia although it was leaking i'd have car warm to drive then a few mins from home turn heater off and open all windows
Offline Mattyj
« Reply #14 on: 29 December 2013, 13:47 »
Checked pollen filter its fines all drain holes in doors clear boot dry don't know where the sunroof drains are also had a pack of wet wipes in rear footwell could this of caused it?
