Author Topic: Keyless - locking issue.  (Read 12528 times)
Offline Andyduz
« on: 26 November 2013, 18:39 »
Anyone with keyless had any difficulty getting the car to lock when touching the handle? I get a dash message about 'safe lock' and the handle often doesn't respond. Opening is fine and works first time.
Delivered 21st Nov. GTD Pure White, Keyless, Winter Pack, Dynaudio, Tel Prep, High Beam Assist, Climate Screen, Discover Nav, Park Assist, Rearview Camera, Voice Activation
Offline DougL
Re: Keyless - locking issue.
« Reply #1 on: 26 November 2013, 18:46 »
Safelock has nothing to do with the keyless system. We all get that message. It just means that the car will deadlock and anyone inside won't be able to get out.
Tornado Red GTI 3dr manual
Previous Golfs Mk1 GLS and GL, Mk2 GL and Driver, Mk3 GL, Mk4 GT TDI, Mk6 TDI (and a Mk2 Scirocco 20 years ago)
Offline Andyduz
« Reply #2 on: 26 November 2013, 18:49 »
Ah, ok. Any clues on the handle issue? It ought to lock with a light touch but certainly isn't doing so. Maybe a trip to the dealer is needed.
Offline CraigW
« Reply #3 on: 26 November 2013, 18:55 »
Is it not working full stop? Mine very very occasionally doesn't lock but when this happens I just open and close the door and try again, this tends to work. Silly question, but are you making sure the doors are properly closed as they need a bit of a slam to shut them properly.
Offline Andyduz
« Reply #4 on: 26 November 2013, 18:58 »
Yeah, doors are shut properly. I have tried opening and re shutting and this does work, it just defeats the purpose and makes you look a bit daft when you can just use the fob :sad:
Offline CraigW
« Reply #5 on: 26 November 2013, 19:01 »
I think it's just one of those things unfortunately. Thankfully it happens very rarely as if the sensor is not picking up your hand but I've no reason to suspect there is anything wrong with it
Offline domrees
« Reply #6 on: 26 November 2013, 22:21 »
Showed my brother in law the car the other day. Said that the car was coded to me, and will only open with my hand. "A bit like James Bond's gun in skyfall"
Had the fob in my pocket, every time I tried obviously it worked. Every time he tried I stood back a little.
Didn't work, and he got increasingly confused as to how it was happening.
Who said keyless entry can't be fun eh?
3dr Manual in Pure White with PP, Dynaudio, Nav and Keyless. Oh and a service pack.
Offline Skinnee D
« Reply #7 on: 26 November 2013, 22:39 »
Try swiping your finger along the handle slot rather than tapping it - I find that works well.
GTD + 3 pedals :-)
Offline AlanH
« Reply #8 on: 27 November 2013, 06:26 »
+1. Seems to work better for me too.
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline Mark V GTD
« Reply #9 on: 27 November 2013, 08:22 »
All you chaps with 'Keyless Entry' - dont forget your key!  :evil:
