Author Topic: Fuel Pump bhp?  (Read 3398 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Fuel Pump bhp?
« on: 24 November 2013, 20:04 »
Does anyone know what bhp a standard fuel pump for an AUM engine can handle?
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline golfyste
  • Project track car
Re: Fuel Pump bhp?
« Reply #1 on: 25 November 2013, 11:34 »
There is no definite number seen as these cars are all quite inks now and many of the fuel pumps arnt as good as they used to be!
So with any decent power you should be looking at upgrading the pump for safety.
There was a aum at r tech last week where he stopped tuning at 200bhp because the fuel pump gave up!
A new aum unit will give about 260-290 bhp
Offline barrym381
Re: Fuel Pump bhp?
« Reply #2 on: 25 November 2013, 11:39 »
did you not just have a new 1 fitted at r-tech  :smiley:
Re: Fuel Pump bhp?
« Reply #3 on: 25 November 2013, 19:44 »
I did have one fitted there because my old one couldn't stand up to the job for stage 2. It came from TPS and is the standard one for the AUM. The reason I ask is because three times while driving and putting my foot down, suddenly there is no power at all, although the car is still on and running, it is as if the accelerator has just stopped working. While this happens the EPC light came. As soon as I re-start the engine, the car is fine again. This does also throw a code up showing a problem with torque!
I just thought that this may of been the new fuel pump that caused the problem.
Offline barrym381
Re: Fuel Pump bhp?
« Reply #4 on: 25 November 2013, 22:01 »
cant see the pump being the problem i might be wrong though what codes does it throw up  :smiley:
Re: Fuel Pump bhp?
« Reply #5 on: 25 November 2013, 22:26 »
Yeah, that is what Nick at R-Tech said too. He told me to clean the TB and do a TBA and adjust the actuator to two turns of pre-load.
The code it showed was 17743/P1335 - Engine Torque Monitor 2: Control Limit Exceeded
Offline barrym381
Re: Fuel Pump bhp?
« Reply #6 on: 25 November 2013, 22:28 »
nick will have a better idea than me  :grin:  ross tech info
     Malfunction Indicator Light (MIL) ON
    Reduced Power
Possible Causes
    Intake hose(s) or intake system leaks (Unmetered Air) after MAF
    Intake Air Temperature sensor faulty
    Mass Air Flow Sensor (G70) faulty
    Engine Coolant Temperature sensor faulty
    Restricted Air or Fuel Filters
Possible Solutions
    Check intake hose(s) or intake system for leaks (Unmetered Air) after MAF
    Check Intake Air Temperature sensor
    Check Mass Air Flow Sensor (G70)
    Check Engine Coolant Temperature sensor
    Check Air and Fuel Filters
Special Notes
    Check O2 Sensor(s) Adaptation Values Before Clearing Faults: Fuel Trim Information
« Last Edit: 25 November 2013, 22:32 by barrym381 »
Offline golfyste
  • Project track car
Re: Fuel Pump bhp?
« Reply #7 on: 25 November 2013, 22:32 »
I've also been gettin that code but I put it down to me puttin a slightly bigger turbo on and not yet having the map adjusted! But I'm not 100% sure
Update and let us know if you sort it please  :smiley:
Re: Fuel Pump bhp?
« Reply #8 on: 25 November 2013, 23:22 »
I have been looking it up on the net and there are various suggestions of the cause, from the maf to the actual map! So I don't know what to think, but I do know when driving in the fast lane of the motorway doing 70ish  :wink: it is a bit of a scary moment when the throttle response totally goes, especially at night time!
Re: Fuel Pump bhp?
« Reply #9 on: 28 November 2013, 09:24 »
Update for those who are interested.
I did a TBA as Nick at R-Tech suggested and all seems well. I have had no more EPC lights come on or that torque code show either. All I have had now and then is the traction control light flicker sometimes when I put my right foot down.
