Author Topic: Just about to get water pump and cambelt done is there anything els to be done.  (Read 3244 times)
Offline Shizzle
As it says above new water pump front part idler/tensioned and cam-belt a mechanic in my garage is charging me next to nothing to do this work so is there anything else i could change while some parts are removed from car do it all in one go?
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Id stick a new thermostat, power steering belt and auxiliary belt in as well mate if they've not been done recently. Are you changing the auxiliary tensioner wheel as well as the cambelt thermo tensioner?
Offline sharki786
  • GOT BOOST??
My man got there before me lol. Change all the belts.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Shizzle
i done thermostat other day because of the overheating and all belts look good evan the cam-belt but when a previous owner says "i changed the belt myself out side my flat" gives me no confidence and as its my daily and ofter doing 400 mile weekends to in-laws cam-belt will be re done :D.
So just change all the belts then as other stuff has been covered.
Offline boneybradley
  • Back in a Mk3...
I don't do the water pump with the cambelt, never had one fail on an mk3 and it doesn't need the belt off to replace (then again I'm from Yorkshire so spending money is bad!)
but as said get all the belts swapped over as they really need to come off to sort the cambelt
I've changed 4 mk3 water pumps over the past few years, all worked fine but were noisy / sloppy in operation.
Offline Shizzle
well i have an engine from previous golf had all belts and water pump changed about 3  weeks before i broke the car and has been sitting for about a month so going to use that water pump and belt as nearly new and still in great condition.
Im thinking crank seal as well and maybe reseal sump as think there is a small leak.
Offline gasketface
oooh,crank seal,you're brave  :whistle:
Offline Shizzle
Why you say that :undecided:
