Author Topic: Which discs and pads?  (Read 4998 times)
Offline D1andonlyantman
« on: 11 November 2013, 17:10 »
Hi. I got the warning light for brakes on my gti 180 a couple of weeks ago. A friend had a look and said the rear look ok for now but the front pads and discs could do with replacing. I won't be doing any track days so don't need anything too expensive but wouldn't mind getting some brembos or something like that. I found these fronts and rears on eBay and just thought they looked a bit cheap considering it's front and rears with pads and was just wondering if they're what I want or if I should be looking for something else. I'm sure this has been asked before but I had a quick search and didn't find what I was looking for.
http://www.ebay.co.uk/itm/GOLF-MK4-1998-2004-BREMBO-DRILLED-GROOVED-BRAKE-DISC-BREMBO-PADS-FRONT-REAR-/300540852210?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AGolf%7CPlat_Gen%3AMK+IV&hash=item45f9a177f2
Thanks
MKIV AUQ - RamAir Induction Kit, Forge007p, (Custom Exhaust, Decent TIP, N249 Bypass and remap coming soon)
TRASHED BY SOME BELLEND WHO CANT DRIVE
Replaced with Leon Cupra 225, RamAir CAI, Forge 007p, Badger5 TIP, N249 bypass, Scorpion Decat and Catback, R-tech remap pushing approx 275bhp :-)
Offline JWebb
Re: Which discs and pads?
« Reply #1 on: 11 November 2013, 17:12 »
I've always used Pagid's for disks and pads and have no complaints.
if you get them from euro car parts you can take advantage of the forum discount as well.
Jack
« Reply #2 on: 11 November 2013, 21:29 »
I would avoid drilled discs as they tend to crack.
Offline dom
  • Back in a Mk4
« Reply #3 on: 11 November 2013, 21:41 »
Any they are completely unnecessary on a MK4 golf.
Pagid is always a safe bet, I'm running Apec on mine and they do the job fine :afro:
Offline brewey
« Reply #4 on: 12 November 2013, 00:06 »
Ive got mintex all round. Work well althogh a bit of squeal with light braking. I think I paid less than a ton for all four discs and pads.
2000 1.8T ARZ - OEM+
Offline Bellend
« Reply #5 on: 12 November 2013, 01:05 »
I did brake pads on an Audi RS5 today, lovely motor a friend of the family has had it from new (2011) he said it's never had brakes done before.
I removed the pads and they have Pagid stamped on them. If they'll do from factory for an RS5, they'll do for a Golf.
Where all my moneys went.
« Reply #6 on: 12 November 2013, 02:20 »
I'll have a little look for some pagids then I guess. Thanks fellas
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #7 on: 12 November 2013, 07:56 »
I think Pagid are what Porsche use too.
I use Brembo discs and pads on the front and they are really good.
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
« Reply #8 on: 12 November 2013, 13:02 »
All of the pagids I've seen are just a flat surface rather than grooved or anything. Would you say they're good enough and buying more expensive ones would be overkill for what I'm going to be using them for or if I can afford better ones then get better ones? I Don't want to waste my money but I don't want to cheap out either
Offline Rhyso
« Reply #9 on: 12 November 2013, 16:28 »
Standard discs are fine  :smiley:
