Author Topic: Which discs and pads?  (Read 5004 times)
Offline Rhyso
Re: Which discs and pads?
« Reply #20 on: 13 November 2013, 08:33 »
On eurocar parts it's was 20 each rear disc, 35 each front. Then the pads. I got everything for 189. Seemed like a fair deal
Ah thought you had only bought the fronts!! Not the full set.....as you stated it was the fronts that needed replacing
Offline D1andonlyantman
« Reply #21 on: 13 November 2013, 14:01 »
Ah I see. Nah, the whole lot
MKIV AUQ - RamAir Induction Kit, Forge007p, (Custom Exhaust, Decent TIP, N249 Bypass and remap coming soon)
TRASHED BY SOME BELLEND WHO CANT DRIVE
Replaced with Leon Cupra 225, RamAir CAI, Forge 007p, Badger5 TIP, N249 bypass, Scorpion Decat and Catback, R-tech remap pushing approx 275bhp :-)
Offline paulhgti
  • GOLF 1.8T AUM 209bhp 228LB FT TORQUE
« Reply #22 on: 16 November 2013, 21:15 »
I have ebc green stuff pads and ultimax grooved discs they are pretty good and no brake dust
AUM 209 BHP R-TECH STAGE 1 RE MAP,MILTEK CAT BACK 4MOTION EXHAUST,4MOTION VALANCES,PIPERCROSS FILTER,TINTS,WIND DEFLECTORS,BOOST LEAK,SANTA MONICA ALLOYS,35mm H&R LOWERING SPRINGS
« Reply #23 on: 19 November 2013, 19:10 »
My mate just went to stick on the discs and said that I need vented on the rear and the solid brembos I've got won't fit. Does that mean the rear brakes have been modded? On the eurocarparts website it says solids on the rear and these were definitely advertised for my model.
Thanks
Offline dom
  • Back in a Mk4
« Reply #24 on: 19 November 2013, 19:35 »
Thanks
If yours is an AUQ (which I'm guessing from your sig) then you'll have 256mm vented rears as standard.
« Reply #25 on: 19 November 2013, 19:48 »
Dammit. Both eurocarparts and the place I bought them from both lied. Bloody irritating. Try and do the research but still get the wrong bloody bit. Well now I know. Cheers mate
Offline dom
  • Back in a Mk4
« Reply #26 on: 19 November 2013, 19:54 »
If you bought them from ECP then take them back. AUQ has 312mm front and 256mm vented rear as standard  :wink:
Offline barrym381
« Reply #27 on: 19 November 2013, 19:58 »
then order them from carparts4less get them cheaper  :smiley:
