Author Topic: Help identifying part  (Read 2838 times)
Offline 150+
« on: 05 November 2013, 21:11 »
Could someone tell me what the part is that sits at the top right side of the engine just below the TIP, it looks like a "flying saucer"
Was driving home with my newborn son and the car started overheating, opened the bonnet and steam/water was pissing out of said part, I plan to replace expansion tank, thermo, coolant and poss water pump, little bit anal at times lol!! But obviously the unidentified part is the prob so need to know what is is
Offline dom
  • Back in a Mk4
Re: Help identifying part
« Reply #1 on: 05 November 2013, 21:15 »
This?
Offline 150+
« Reply #2 on: 05 November 2013, 21:17 »
No
Just below that on the underside of the tip, it metal
Offline 150+
« Reply #3 on: 05 November 2013, 21:22 »
Offline Chris#101
« Reply #4 on: 05 November 2013, 21:45 »
It's the s.a.i valve (secondary air intake)
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline 150+
« Reply #5 on: 05 November 2013, 22:01 »
Ok
Why would water be coming out of it??
Offline 150+
« Reply #6 on: 05 November 2013, 22:15 »
What's the price off a new one can't seem to find them anywhere??
Offline dom
  • Back in a Mk4
« Reply #7 on: 05 November 2013, 22:17 »
There shouldn't be, it pumps air into the exhaust on startup.
You can just remove it:
http://forums.vwvortex.com/showthread.php?4893472-DIY-Ultimate-SAI-N249-PCV-EVAP-Delete
Offline 150+
« Reply #8 on: 05 November 2013, 23:39 »
Seems like a lot of work!! And to be honest I'd rather spend the time with my son while I'm off work. Does it have a gasket that could have blown??
Offline mcgee9t2
« Reply #9 on: 06 November 2013, 06:46 »
Fix the problem not the effect. It shouldn't have water /steam coming out of it afaik so removing it is only going to mean the water ends up somewhere else. Sorry I can't be more help I have no idea how water or steam would even get there...
