Author Topic: turbo flutter, just started out the blue??????  (Read 4074 times)
Offline cooki
  • 1.8T AUM
« on: 27 October 2013, 13:41 »
Ive had a forge split r fitted for about a year on full recirc mode and has been fine nice whoooosh when I back off the throttle as it should do, but the last few days instead of the usual whoosh im getting full on chatyer/flutter now.
Any ideas?
Ive fully greased the valve/spring up and messed with the tention settings as per forge website but still full chatter.
Could it be down to my n249 or n75 valve neeing faulty????
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline EsSeX dAn
Re: turbo flutter, just started out the blue??????
« Reply #1 on: 27 October 2013, 17:25 »
check the vacum to the recirc valve
i think i love you.....
Offline cooki
  • 1.8T AUM
« Reply #2 on: 27 October 2013, 22:35 »
Checked it, all seems good.ive already replaced it with silicone vac tubing and its still all fine :( :(
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #3 on: 27 October 2013, 22:36 »
Personally i would swap that split r for this http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=260301&product=FMCL007P yours being an aum engine would be better with a closed loop valve fitted :afro:
2000 Mkiv GTi 1.8T AGU
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #4 on: 29 October 2013, 11:03 »
I had this issue after I changed from hybrid set up to fully recirculating and also after I put in a new TIP. Just had to adjust the tension took a couple of attempts after test drives but its fine now all good!
Have you fitted anything or changed anything recently?
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
jamie16v
« Reply #5 on: 29 October 2013, 13:52 »
i have recently had some flutter from my 007p, also some jerking / surge when lifting off but only since fitting the E05 turbo. It had me scratching my head for ages, thinking it could be the engine mounts etc.
I fitted a blue spring last night to see if that has cured it, I haven't been on a "proper" drive to test it yet but it now seems fine on casual driving.
but as stated by northeast gti, your engine would be better suited to the fully recirculating 007p.
Offline cooki
  • 1.8T AUM
« Reply #6 on: 30 October 2013, 11:44 »
This morning I have fitted my OEM recirc valve and I have been on a proper run and have noticed that the car is onlu boosting to 3-4 psi. No visible boost leak.
Any help appreciated.
jamie16v
« Reply #7 on: 30 October 2013, 12:17 »
how much boost was it running with the forge dv?
it probably knackered the OEM one, bin it!
it could be a number of things, if youre in limp mode it will run at actuator pressure so check for codes.
check the n75 is plugged in??
« Last Edit: 30 October 2013, 12:20 by jamie16v »
Offline cooki
  • 1.8T AUM
« Reply #8 on: 30 October 2013, 12:24 »
Oem recirc was fine b4 I fitted forge and forge has been fine for a good year so thinking its something else not the recirc valves.
It was boosting to a normal healthy 7 ish psi.
Its not in limp mode its just not boosting properly.
N75 valve is plugged in but im guessing it could be faulty??
I havnt got a vagcom to hand so guessing and doing it blind at the moment
jamie16v
« Reply #9 on: 30 October 2013, 12:41 »
ok. I`d suggest putting the forge unit back on, adjust it to fully recirc and go from there.
what vac line are you using to go to the DV? if it`s the old rubber one change it to silicone.
