Author Topic: turbo flutter, just started out the blue??????  (Read 4079 times)
Offline cooki
  • 1.8T AUM
Re: turbo flutter, just started out the blue??????
« Reply #10 on: 30 October 2013, 12:51 »
Ive already put the forge on fully recirc mate and re greased the spring an so on as per the forge website.
Im also already using upgraded silicone tubing for the vac line.
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
jamie16v
« Reply #11 on: 30 October 2013, 13:03 »
I would stick with the forge for now, perhaps fit a stronger spring?.
have you looked at the condition of the piston?
 I would do the n249 bypass anyway! http://www.golfgtiforum.co.uk/index.php?topic=113646.0
« Last Edit: 30 October 2013, 13:07 by jamie16v »
Offline cooki
  • 1.8T AUM
« Reply #12 on: 31 October 2013, 23:11 »
I can't see both of my DV being faulty at the same time,
Still no further with this,still fluttering away,
Still only boosting to around 3/4 psi,
The n249 bypass is way out of my technical abilities,
Guessing a smoke test could be next to look for boost leaks??
jamie16v
« Reply #13 on: 01 November 2013, 21:03 »
take it to someone to look at, it`s hard to diagnose your problem over the internet. it needs to be seen in the flesh!
