Author Topic: whys no one use aftermarket cams on a 1.8t?  (Read 2381 times)
Offline davemk4
« on: 20 October 2013, 17:23 »
even though i have no interest in messing with my cams. ive yet to see a member with aftermarket cams? how come as for sake of fitting them you get good gains? wouldnt this be good to do for stage 2?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
VW BUSH
Re: whys no one use aftermarket cams on a 1.8t?
« Reply #1 on: 20 October 2013, 17:45 »
Pair of cams £450? BHP gain 20? (if your lucky)
Remap £450? Gain 50bhp?
Offline davemk4
« Reply #2 on: 20 October 2013, 17:56 »
ye but if you were wanting as much power as possible without maybe changing turbo and the extras needed. this would mean a big power stage 2 remap at a guess?
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #3 on: 20 October 2013, 18:06 »
They can be a bit of a false economy with modern forced induction engines.
Offline Adam
« Reply #4 on: 20 October 2013, 18:29 »
NA 1.8 20V cams giv good gains don't they?
Down Hill From Here.
Offline gazareth
« Reply #5 on: 20 October 2013, 19:08 »
you can get massive power gains on turbo engines before you have to consider a cam swap.
Offline golfyste
  • Project track car
« Reply #6 on: 20 October 2013, 20:36 »
From what I have gathered the isn't much to be gained from cam swaps on 1.8t's.
Prawn did the 1.8n/a cam swap on his and the gains were debatable as he gained a tiny amount in one part of the rev range but lost it in another.
I'm still waiting to be convinced its worth the effort!
Offline davemk4
« Reply #7 on: 20 October 2013, 21:05 »
They quote 15bhp + on cam websites iirc.
Offline golfyste
  • Project track car
« Reply #8 on: 20 October 2013, 21:07 »
Any actual evidence though using back to back dyno runs?
I've also seen manifolds and exhausts that quote "upto +20bhp" etc
Offline mrsaunders
« Reply #9 on: 21 October 2013, 11:33 »
Aren't the turbos limited to around 230-250 max, so where would you fit this extra (debatable 20bhp)
