Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120866 times)
Offline itavaltalainen
Re: MK7 and VCDS (VAG-COM) thread
« Reply #550 on: 13 July 2014, 15:41 »
1 - Seatbelt Warning disable
not possible to have auto hold ... why do you want to use stop/start anyway, it's pointless
why people don't use seat belts i don't know (have the warning disabled myself for maneuvering)
2 - Reverse mirror down function
only one mirror will go down, imho cannot be coded to be both although theoretically it should be possible
you can close the windows with the remote control, just push the button until the windows are all up
you cannot retrofit driving profiles afaik, at least not with vcds
Offline GTD_777
« Reply #551 on: 16 July 2014, 13:04 »
Anyone in Bucks Beds or Oxfordshire that would be willing to help code some little things on my GTD?? In return for ££ or Beers obviously  :smiley:.
I'm based in Aylesbury but willing to take a little drive.
Offline szcll2008
« Reply #552 on: 29 July 2014, 16:35 »
Hello!
I want to install "dynaudio" with my golf7,but I don't known the module coding.
Could you tell me the the module coding of VCDS in your golf7: address 09 /address 47 /address 5F?
Thank you very much!
Offline szcll2008
« Reply #553 on: 29 July 2014, 16:51 »
Hello!
Offline p3asa
« Reply #554 on: 29 July 2014, 19:31 »
My car doesn't have address 47 but here are the other 2.
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011411300752
   Coding: 03000A46C24122FB0BA44080B11C07281000000000000000000000000000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 7BF50ADAF28ABBC6CE5-802E
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
   Component: WWS    140407  042 0551
   Serial number:         140411101839
   Coding: 0E4DDD
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels: 5Q0-955-547.CLB
   Component: RLFS  024 0042
   Serial number: Y14M04D26H17M29S55S8
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY140790VCE
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000059331822
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5G0 035 020 C    HW: 5G0 035 020
   Component: MU-H-ND-EU    H40 0290
   Serial number: A458D0E7509209
   Coding: 027300010000000011111202000800001F0202F60100010057
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS.rod
   VCID: 1939305218F669D67C9-804C
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 606     HW: 5G0 919 606
   Component: ABT_High  H51 0022
   Serial number: VWZ8Z9PJ600WUW
   Engine Control Module 2:
   Subsystem 2 - Part No SW: V03 959 800 GP    HW: -----------
   Component: ECE 2014  --- 0078
   Serial number: --------------------
   Door Electronics Rear Left:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 1008
1 Fault Found:
6720 - Rear View Camera
          B1102 31 [008] - No Signal
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 131
                    Mileage: 1078 km
                    Date: 2014.06.11
                    Time: 15:28:43
Offline szcll2008
« Reply #555 on: 30 July 2014, 12:17 »
Thank you!
It will be perfect if you show all the scanning by the VCDS.
 Looking forward to hearing from you!
Offline TheCarMadDad
« Reply #556 on: 30 July 2014, 16:08 »
Anyone in the Derby area who is willing to do the DRL tweak for me? Money or beer a pleasure...
2014 Mk7 Golf GTD 5dr | Tornado Red | Keyless Entry | Climate Comfort Screen > Which means I also have the ATP. Also fitted with DTUK Stage 2 box ...Loving every second behind the wheel!
Previous...
2008 Toyota Prius T Spirit (fastest 0-15mph car I have ever owned :p )
2005 Subaru Legacy 2.5 SW
2003 Lexus IS300
2002 Seat Leon Cupra R
Offline remlapeel
« Reply #557 on: 30 July 2014, 23:03 »
Long shot but anyone in the norwich area willing to do a few tweaks?
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline szcll2008
« Reply #558 on: 31 July 2014, 13:19 »
Thank you!
Offline aussiegolfer
« Reply #559 on: 07 August 2014, 00:54 »
Hi All,
New to the forum, just got my Golf MK7 90TSI DSG.
I bought a new OEM Steering wheel with Tiptronic paddles to replace my original which did not.
Installation by my mechanic was fine, and the paddles work without issues.
However, the EPC light is on and also there is now an error in the Auto Stop/Start function and cruise control.
Mechanic tried to code with VCDS but failed because he couldn't figure out the new codes.
If anyone knows how to code a Steering wheel with DSG paddles, would love some help.
much appreciated!
