Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120866 times)
Offline kevinm
Re: MK7 and VCDS (VAG-COM) thread
« Reply #560 on: 07 August 2014, 12:04 »
1 Fault Found:
6720 - Rear View Camera
          B1102 31 [008] - No Signal
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 131
                    Mileage: 1078 km
                    Date: 2014.06.11
                    Time: 15:28:43
My car has the same rear view camera fault. Did you ever ask your dealer about it? My camera sometimes does strange things like black screen.
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline mcmaddy
« Reply #561 on: 07 August 2014, 13:29 »
I think this error is from leaving the car in reverse and not having the ignition turned on. Car thinks camera is faulty due to no power going to it. Don't think it's anything to worry about though.
Offline p3asa
« Reply #562 on: 07 August 2014, 13:59 »
I've not been aware its happened 3 times like the fault code says.
I was aware of it happening once but I put it down to me putting it into reverse then straight away putting it into 1st so I thought I was too quick for the system.
It resulted in me reversing with a black screen.
« Last Edit: 07 August 2014, 15:56 by p3asa »
Offline Noodile
« Reply #563 on: 09 August 2014, 20:31 »
Can anyone that DISABLED DRL  (or at least enabled that option in the menu),  can you please post your coding on here?
like the long coding instead of the instructions
"Go to [09] Central Electrics
Go to Access
Enter code 31347
Go to Adaptation and change:
"Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich" to Active"
Offline JB GTI
« Reply #564 on: 10 August 2014, 11:41 »
Can voice activation be added via  VCDS seeing as there are already voice button and the head unit and steering wheel or was it a box that needed ticking when ordering. My brother in law has just picked up a new Seat Leon FR And it has it as standard and seems to work really well.
Now Gone: 3dr GTI Carbon Grey Performance Pack Dynaudio
Discover Nav Park Assist Rear Camera
Picked Up: 15th March 2014
Now Gone 3dr Golf R Lapiz Blue, DSG, Dynaudio, 19" Pretoria's, Discover Nav, Keyless, Rear View Camera
Picked Up: 1st March 2015
Now Gone Too: Mk7.5 Golf GTi Performance 5dr Indium Grey DSG Dynaudio 19” Brescia Alloys Vienna Leather Keyless Entry/Start Panoramic Roof 90% Tints Park Assist Rear View Camera Voice Activation Dynamic Lane Assist/DLA
Offline mcmaddy
« Reply #565 on: 10 August 2014, 12:53 »
Voice activation is standard with the nav pro but not on discover. It may be activated by vcds but I doubt it.
Offline remlapeel
« Reply #566 on: 10 August 2014, 14:26 »
Sorry if it's been asked before but how difficult is it to get hold the cables and software to be able to do this myself? what's the sort of cost involved?
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline mcmaddy
« Reply #567 on: 10 August 2014, 20:06 »
I wouldn't bother the voice activation is rubbish anyway.
Offline valvebounce
« Reply #568 on: 10 August 2014, 22:18 »
Not difficult. $249 + shipping from here: http://store.ross-tech.com/shop/VCuCAN.html
Offline p3asa
« Reply #569 on: 11 August 2014, 09:58 »
You can also get them in the UK from
http://www.ilexa.co.uk/acatalog/vagcom.html
http://www.gendan.co.uk/product_VCHU_9.html
The Gendan link gives a comparison between the micro can & the +can
Basically the +can is more backward compatible but is dearer.
Buying the +can from there works out about £15 dearer than buying from the US but I'm not sure if you would have to pay import duties if it came from the US?
