Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120872 times)
Offline valvebounce
Re: MK7 and VCDS (VAG-COM) thread
« Reply #570 on: 11 August 2014, 21:35 »
The micro can from gendan is a good price, not worth buying in the US unless you're visiting & can ship to a local address.
Offline szcll2008
« Reply #571 on: 13 August 2014, 13:12 »
Thank you!
It will be perfect if you show all the scanning by the VCDS.
 Looking forward to hearing from you!
 :smiley:
Offline cebbes30
« Reply #572 on: 17 August 2014, 19:57 »
Hello Guys,
I have a problem, i have change today my right rear door ,but i have a error.
The door was complete with window motor and the lock mechanik.
Only thing i have done is connect, after this the error come.
So i have change all the old components back, after scanning VCDS a cant get of the error.
Can anyone tell me what i can check to permanent erase the error!!
address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS H12 0006
Serial number: 03081200010093
Coding: 00110020DE00020000801000
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000247280
Coding: 090000
1 Fault Found:
65588 - Motor for Window Regulator
B1487 54 [009] - Missing Calibration / Basic Setting
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 118
Mileage: 19809 km
Date: 2014.08.17
Time: 19:59:01
Thanks waiting for any tips!!
Offline jivemonkey
« Reply #573 on: 11 September 2014, 08:22 »
Hello fellow tweakers.
Long time no post. Haven't been on the forum in months due to a certain very small new member of the family arriving.
With free time at an all time low, (and as such the GTD is embarrassingly dirty), I've got my genuine Ross-Tech cable on eBay, should anyone be after a bargain. Item number 151407021629.
Cheers.
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline aqxavier
« Reply #574 on: 18 September 2014, 20:43 »
Hi...
I have a problem in my MMI / 3G (5F) :(
When performing the uploading the ZDC to unlock the VIM lost all parameters Adaptation Bluetooth, WLan, RSAP, SIM Card, NET.
How can I have these parameters for adaptation again? Is there any ZDC to return to the original mode, Bluetooth Premium?
My unit is: 5G0035045B HW: 042 SW: 0291
Coding: 027300030000000011220002001800001F0203F401000100D7
Offline jbale
« Reply #575 on: 20 September 2014, 21:45 »
Hey everyone,
This thread has been great! Its nice to have most of the tweaks in one place.
I'm trying to straighten out a couple things regarding the LED tail lights and was hoping someone with the LED tails installed from factory could help out. I'd love to get a copy of the 09-Central Electronics module map that includes LED tails. And just overall I would like to compare the adaption channels to those of my Canadian GTI.
If anyone can send me a copy it would be greatly appreciated!!
-Jeremy
Offline Sootchucker
« Reply #576 on: 09 October 2014, 13:30 »
Not posted in this thread for a while, so thought I'd just update it with a minor "tweak" I learned the other day. Not an essential mod by any means but I quite like it.
As you know, when you change driver profiles modes, all the information comes up on the main infotainment screen (including a little text area in the top left corner indicating the currently selected driver profile).
Well with this very simple mod, not only does it display on this but also in the DIS screen when you have finished selecting, but upon starting of the car, it flashes up for just a second or so to remind you of the currently selected profile. One slight amusement is that all my modes appear the same as in the infotainment screen (Comfort, Normal, Sport, & Eco) except one - Individual mode comes up in the DIS as "RACE Mode" vrooom vrooom..........  :grin:
Any the mod is simply to go into the CAN gateway controller [19] and enable the check mark on Byte [8] Bit [4]
That's it, and you should be let with the following:
« Last Edit: 09 October 2014, 14:01 by Sootchucker »
Offline GrahamFR
« Reply #577 on: 09 October 2014, 13:36 »
i like that, going to do hungover tomorrow!
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline gelocatil
« Reply #578 on: 25 October 2014, 23:47 »
Hi to all, im a VW fan and im using vagcom-vcds from a few years but now with the MQB platform and the great amount of adaptations im a bit lost.
Mine is 2.0TDI 150 DSG june 2013, sport model called here. acc sunroof dla etc...
The problem is i dont know if activating the signal recognition in MFA and time passed i checked that in the composition media the tickbox for "stay in centered lane" (sorry for my english) for the lane assist not remains ON in every engine shutdown.
Cannot check at the codinglog.txt cos the VM used had to delete and im from zero now.
If anyone can export the entire A5 and 5F to compare adaptations im very grateful
Greats from Spain and clubvwgolf
Offline gelocatil
« Reply #579 on: 28 October 2014, 12:08 »
finally found a exported adaptation of another golf and encountered the key!
now the setting in the composition media still ticked even switch off the engine
