Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1121038 times)
Offline KyleB
Re: MK7 and VCDS (VAG-COM) thread
« Reply #530 on: 10 May 2014, 10:07 »
Anyone tweaked anything else on their golf then?
Also, I should be getting mine in 8 weeks, is anyone around North Yorkshire are with VCDS to activate a few things? Leeds/Newcastle or anywhere in between?
Thanks
I'm around Durham way mate if you can't find anyone closer.
I'm Richmond, so you may well win some beer tokens when I get my car.
No worries pal.
Offline cebbes30
« Reply #531 on: 23 May 2014, 19:00 »
Hi
I want to now if it is possible to close the open windows with one short push the remote control.
You can recode olso teh mirrors with vcds to fold, so i think it must be possible to recode 09 adaption?
anyone done this?
Offline 182_blue
« Reply #532 on: 02 June 2014, 17:02 »
Anyone done mods on a very recent MK7 ?, its just things like the battery state of charge are not where the guide here says ?
Offline cebbes30
« Reply #533 on: 02 June 2014, 19:30 »
I have a gustion about the vcds byte and bit 09 central elektronic.
Before a have a update this is the code.
00 0C 08 46 C2 41 02 FB 0F A4 40 80 B1 1C 07 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00
And After
00 04 08 46 C2 41 02 FB 0B A4 40 80 B1 1C 07 08 10 00 00 00 00 00 00 00 00 00 00 00 00 00
Byte 1 bit 2 and 3 was enable and after update only bit 2.
Can anyone tell me what this bit 2 and 3 are ?
Byte 8 bit 0,1,2,3 was enable before update and after update bit 0,1,3
Cany any one tell me what is Personilization profiles active this is not enable after update?
Byte 16 None and after update bit 4 External Consumer via Terminal 30G installed.
What will hapen whn i put the old valeus back, will i get errors.
I have let it update because the coming home and leaving home didnt work oke, and after this update its work great.
But i have some time problems with my Media Discover Navi, screen gone wild after a cold start in the morning, when i wave near the screen the screen peeps and somtimes it blocks.
https://www.youtube.com/watch?v=LVKHksho3wE
https://www.youtube.com/watch?v=OapYFCDvPgk
https://www.youtube.com/watch?v=B5xaa2blIvI
https://www.youtube.com/watch?v=bZkO2r-0fkU
https://www.youtube.com/watch?v=8oK98QOGbqc
https://www.youtube.com/watch?v=p-u34-Kfcig
https://www.youtube.com/watch?v=BOf7CTsEBDo
https://www.youtube.com/watch?v=AOxr02D-wdE
https://www.youtube.com/watch?v=JoBpqCPiNEQ
https://www.youtube.com/watch?v=X2vxBBUuJVk
https://www.youtube.com/watch?v=wuMxeZTRi94
https://www.youtube.com/watch?v=G1y1U7WJ8Nc
https://www.youtube.com/watch?v=fbh6Le2zSmY
https://www.youtube.com/watch?v=HoAf7o5IBPA
https://www.youtube.com/watch?v=rq0fYG3m990
Before the update i had never a problem wit the navi, maybe the update whit some of bit are enable?
Offline led.737
« Reply #534 on: 06 June 2014, 14:20 »
Hello everyone!!
Another chalenge for you guys!
I want to keep my DRL lights always ON, even when the head-lights are on....
The thing is! I've upgraded my stock halogen head-light for a generic GTI unit with HID bulbs and that prety "U" shaped arc, which acts as the DRL.
Everything works fine (plug-n-play instalation), but the U arc doesn't stay lit when the main head-light is on (normal behavior for the DRL mode).
Is there any way to change this??
Thanks!!
Offline GrahamFR
« Reply #535 on: 06 June 2014, 14:23 »
Hello everyone!!
Thanks!!
Unhelpfully my U is always on and think thats true for all of us, so normal drl function is ON not OFF
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline Ross Detours
« Reply #536 on: 06 June 2014, 15:15 »
I believe the U does stay on but dips to about 30% brightness. There is a VCDS tweak to keep it at 100% all of the time but I'm afraid I don't know where in the thread it is mentioned.
Offline GrahamFR
« Reply #537 on: 06 June 2014, 15:21 »
if its an aftermarket kit it may not. probably best to contact the seller and ask/complain why its not matching a gti oem
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline p3asa
« Reply #538 on: 06 June 2014, 16:16 »
Possibly because they are from Brazil with different standard options.
Offline led.737
« Reply #539 on: 06 June 2014, 16:54 »
Hi Guys!!
I've just self-solved my problem!
Yes, it's an after-market unit, made to replace the OEM with plug-n-play change. All wires and harnes were included for that, so the car module still "thinks" that the OEM halogen unit is there...
My U didn't stay on as it was assigned as a DRL (replacing the OEM halogen DRL, which turns off when head-light is on).
What I did with VCDS was search for the DRL output light, and assigned a second function to it for normal low beam. This means that the same light now works either as a DRL and as a Low Beam:
My car is a Golf MK7 (MQB) - 1.4 TSi (Germany made - Brazil Market Higline):
[09] Cent. Eletronics
Code 31347
Adaptation
(5) – Leuchte4TFL LB4 – Lichtfunktion B 4 (Whitch is a B function for the LEFT DRL output)
Default: NOT ACTIVE
Changed to: Abblendlicht Link (Left Low Beam)
(5) – Leuchte5 TFL RB32 – Lichtfunktion B 5 (now for the right side)
Default: NOT ACTIVE
Changed to: Abblendlicht Rechts (right low beam)
