Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120873 times)
Offline Mark V GTD
Re: MK7 and VCDS (VAG-COM) thread
« Reply #510 on: 14 April 2014, 23:35 »
To show them go to '08 - HVAC', then to Byte 11 and tick bit 6.
Hmm, strange that as the fan speed LED's have always shown on my GTD irrespective of whether it's in Auto or Manual mode, and has been like that since the day I picked it up ?
Seems there are quite a few minor changes - presume post BW45 - thsi being one of them, I also found things you had activated such as gallons since re-fuel missing on mine...
« Last Edit: 14 April 2014, 23:38 by Mark V GTD »
Offline mcmaddy
« Reply #511 on: 15 April 2014, 08:06 »
Mines a pre bw45 and doesn't show the air con fan speed. It did however have the battery charge and gallons to refuel already activated.
Offline Mark V GTD
« Reply #512 on: 15 April 2014, 14:18 »
Go to Discovery Pro and Reset the Light Settings. Then it will work.
Worked perfectly - thank you again!   :smiley:
Offline triumph61
« Reply #513 on: 15 April 2014, 19:03 »
 :cool:
Offline Mark V GTD
« Reply #514 on: 16 April 2014, 02:22 »
Triumph - can I ask if you have discovered how to turn off headlight wahers with VCDS?
Thank you.
Offline triumph61
« Reply #515 on: 16 April 2014, 14:59 »
Complete Turn Off? You can delay the time. Sorry only in German. I only can copy the settings because i have not VCDS, i only use VCP-Pro.
    STG 09 (Bordnetz) auswählen
    STG Zugriffsberechtigung -> Funktion 16
    Freischaltcode 31347 eingeben
    STG Anpassung -> Funktion 10
    (2) Frontscheibenwischer-SRA Verzögerungszeit auswählen
    Wert entsprechend nach Wunsch anpassen
    Defaultwert: 0 ms
    Beispielwert: 1500 ms - 2500ms
So you have to push 2,5 seconds till the headlight washer are working.
« Last Edit: 16 April 2014, 15:02 by triumph61 »
Offline led.737
« Reply #516 on: 16 April 2014, 16:03 »
Hello everyone!
I've registered in this forum first to thank everyone for the tweaks listed here and, to see if you, nice guys can help me  :smiley::  :whistle:
I own a Golf Mk7 - 1.4 TSI - Highline Version (as it's called here in Brazil).
-Change the way the mirros unfold (I saw some pages back that people wanted the mirrors to unfold when unlock, but I want the other way, i.e., they unfold on the igntion rather then on unlock, because sometimes I just need to pick something at the car, and there's no need for the mirros to unfold)...
-Change the temperature for the side-mirrors heater to kick-in. Their default is 20ºC (68ºF), and and would like them to be 25ºC (77ºF), in order to use it on raining summer days...
-Activate BOTH rear fog-ligts... I saw some people making it on a SKODA forum, which shares the same MQB platform, but didn't succeded doing it on the Golf. Just to let you know, my car has LED tail lights (stock)!
I believe these options are on the adaptation channel, somewhere, but VCDS 12.12 still have a lot of german in it, which makes it hard (impossible) to understand....  :embarrassed:
Here's an auto-scan of Module 9, in case you need it:
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
   Component: BCM MQBAB M   H16 0124
   Serial number: 00011333300887
   Coding: 00111842C24102FB0BA44080B10403281800000000000000000000000000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 79F90B6FF82C89D6D3D-802C
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A
   Component: WWS    131123  042 0551
   Serial number:         131125091413
   Coding: 0E4DDD
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547
   Component: RLFS  024 0042
   Serial number: Y13M11D21H13M30S46S6
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY132982ZMX
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000028229924
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO25260481
   Coding: 181801
Thansk for the help again!
Offline Sootchucker
« Reply #517 on: 16 April 2014, 16:23 »
I think the operation of the auto fold / unfold of the mirrors has pretty much been discussed to death, and the net feedback is that getting the mirrors to unfold on unlock (like the Post Sept 13 cars do) is a hardware change of the door controllers (or it's software), and not something that VCDS can "tweak" I'm afraid.
Offline Sootchucker
« Reply #518 on: 16 April 2014, 16:25 »
OK one from me to the experts out there. If there's one thing that constantly annoys me, it's that when reverse is selected and the rear view camera comes on, the left hand side (with the topographical view of the car) is greyed out for about 5 seconds before fading to clear.
Is there anyway to stop the unit displaying the car graphic on a greyed out background permanently,  so it appears on a clear background at first switch on ?
Offline mcmaddy
« Reply #519 on: 16 April 2014, 17:08 »
Is it not in the settings menu when the camera is activated. Three coloured buttons on the screen I think although this may just be for the camera.
