Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120872 times)
Offline Mark V GTD
Re: MK7 and VCDS (VAG-COM) thread
« Reply #500 on: 11 April 2014, 15:28 »
Chaps - I'm not happy... VCDS seems to be a bit of a challange with the Mk.7. I have done a couple of things without an issue but most recently I am really struggling.
For example I set the indicator comfort blinks to 4 - command accepted - all OK, went back in to VCDS to check and there it is set at four. In practice - stil three blinks. Checked again - still shows 4.... WTF??
Nest job I tried was this:
1. Go to [09] Central Electronics
2. STG access permissions -> Function 16
3. Enter access code 31347
4. Go to adaptation channels (Function 10)
5. Select channel 1 - Select "Number of operations front windsceen wiper washer per SRA activation" (in German - Frontscheibenwischer Anzahl Betätigungen Frontwaschanlage pro SRA Aktivierung auswählen)
6. Adjust value to preference (no of times you can operate the windscreen washer stalk before the headlight washer activate).
7. Select channel 3, and adjust the activate time for folding the switch to enable headlight washers in the first place.
Again, abject failure - firstly using UK/English VCDS I entered the 31347 security code, all OK - but then could not find the adaptation channel - I know there must be 500 lines of commands but I could find nothing that looked right after scrolling up and down for ten minutes.
I then used Sootchuckers suggestion and tried German VCDS - surely enough there was the correct line "Frontscheibenwischer Anzahl Betätigungen Frontwaschanlage pro SRA Aktivierung auswählen"
But I could not get the security section (16) to accept the 31347 access code!
Never had issues with VCDS in year of Scirocco ownership - in fact if I had just got it for this car it would be going back to the supplier for a refund!
Any help gratefully received!
Thanks!
« Last Edit: 11 April 2014, 15:30 by Mark V GTD »
Offline p3asa
« Reply #501 on: 11 April 2014, 17:46 »
I'm reluctant to buy my own VCDS setup but does anyone know of places in central Scotland or any members in Scotland with the system who are willing to do it for some cash/beer?  :wink:
I've got one mate and just down the road  :smiley:
Offline cebbes30
« Reply #502 on: 12 April 2014, 18:50 »
Hello,
Yesterday i have build the cruise control Tempomat and let it code by the dealer with the lizens code to activate.
Everything is oke and working well, but i have two fehlers!
Other Forum Golf 7 users have this done at the dealership and have the same error.
Has asked the dealer, but that seems to look normal after Retrofitting coding!
Is this normal or can this be coded out.
Multifunction unit control module:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H14 0035
Serial number: 23130000529820100291
Coding: 2B0000
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 5430458201
2 Faults Found:
8782084 - Tiptronic Downshift Switch/Paddle in Steering Wheel
B114E 96 [009] - Component internal failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 14568 km
Date: 2014.04.12
Time: 13:37:48
8782085 - Tiptronic Upshift Switch/Paddle in Steering Wheel
B114F 96 [009] - Component internal failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 14568 km
Date: 2014.04.12
Time: 13:37:48
Offline triumph61
« Reply #503 on: 13 April 2014, 10:23 »
Thanks!
Go to Discovery Pro and Reset the Light Settings. Then it will work.
Vcds has Problems with the MQB Cars. For Example, with VCDS it is not possible to get Rainclosing working, because the RLFS can not be coded. VCP- Pro can do this since 07/2013.
You want the clear Coding of the 42 and 52? Look at this 6 Photos Stg42 + stg 52.
https://drive.google.com/?authuser=0#folders/0B5INjAze86wxVFdRV19lTEZrb1k
« Last Edit: 13 April 2014, 10:25 by triumph61 »
Offline Mark V GTD
« Reply #504 on: 13 April 2014, 19:59 »
Thanks Triumph... yes there certainly are issues!
What do you mean exactly - the factory re-set for the lights?  That will get the system to respond to my VCDS adjustment?
Thanks again.....
Offline C2K
  • Northern Monkey
« Reply #505 on: 13 April 2014, 20:21 »
When was yours built? My bw51 is doing similar things,  for instance changing the taillights to on permanently with drl,  battery charge state etc... command accepted but didn't work. Tried 4 things and only rain closing worked in terms of something changing,  i.e. The menu feature appeared but can't say I had time to test it.
5 Door Night Blue GTD
Dynaudio, 19" Santiago Alloys, Adaptive Chassis, Leather Pack, Winter Pack, Reverse Camera.
Bianca White 306 Rallye (Supercharged + Caged) : Melting Silver F54 Mini Clubman Cooper S
Offline Mark V GTD
« Reply #506 on: 13 April 2014, 22:32 »
BW8 - two weeks since collection. I did get VCDS to do three or four things - mirror lights on while folding, silence seat belt warning alarm chirp and fan lights showing on Auto....
« Last Edit: 13 April 2014, 22:34 by Mark V GTD »
Offline triumph61
« Reply #507 on: 14 April 2014, 09:06 »
Thanks again.....
You have to reset only the Light Settings in the Discovery (factory Reset Light). After that the Discovery will take the Settings stored in BCM / ECU 9. Thats all.
Offline Mark V GTD
« Reply #508 on: 14 April 2014, 13:35 »
Thanks again - I will give that a go!
Cheers  :smiley:
Offline mcmaddy
« Reply #509 on: 14 April 2014, 19:12 »
Mark what did you do to activate the auto air con lights?
