Author Topic: central locking issue  (Read 1697 times)
Offline Luke1981
« on: 29 September 2013, 19:13 »
The boot won't lock when using the central locking fob. Had a quick look before and water is escaping when I use the rear washer.  I obviously need to repair the pipe and connector which I'll sort out this week. I'm presuming the water leak has effected the electric motor which locks the boot.
Will I need to replace the motor or will it work again when it's dried out?
Thanks
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline northeast_gti-t
  • "1.8T AGU"
Re: central locking issue
« Reply #1 on: 29 September 2013, 19:21 »
Thanks
it will have affected the lock and microswitch also so you will need to replace this the same as me as mine did the same  :angry: i stripped my motor and it was beyond repair tbh you can get a service kit afaik for them but buying another motoer would probs be the best bet,all i did then was pull the motor out and rear wiper assembly block and seal the water pipe and plug the rear glass where the wiper spindle goes i tend not to use the rear wiper  :grin: well i won't be doing now  :whistle:
2000 Mkiv GTi 1.8T AGU
Offline Luke1981
« Reply #2 on: 29 September 2013, 19:46 »
Thanks for the help.
I have seen this on ebay
http://www.ebay.co.uk/itm/GENUINE-VW-MK-4-GOLF-BOOT-LOCK-SOLENOID-/271285535763
Is this the part I need?
« Last Edit: 29 September 2013, 19:50 by ljl1981 »
  • "1.8T AGU"
« Reply #3 on: 29 September 2013, 21:28 »
No problem  :smiley:
The part you show the link for is the actual boot lock solenoid you will need this : http://www.ebay.co.uk/itm/VW-GOLF-MK4-BOOT-TAILGATE-LOCK-CATCH-MECHANISM-GENUINE-/281137108771?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item417513d723 this is where the microswitch is that gets wet and fails when the washer pipe and motor leak
hope this helps
Offline Luke1981
« Reply #4 on: 29 September 2013, 22:22 »
Thanks mate. Is it a straight forward job?
« Last Edit: 30 September 2013, 06:24 by ljl1981 »
  • "1.8T AGU"
« Reply #5 on: 30 September 2013, 21:48 »
no worries,yes its an easy enough job to do  :wink:
  • "1.8T AGU"
« Reply #6 on: 30 September 2013, 21:53 »
Some good help and advise here too.... http://www.golfgtiforum.co.uk/index.php?topic=150271.0
Offline Luke1981
« Reply #7 on: 01 October 2013, 02:39 »
Fantastic guide. I think I will crimp the water pipe and replace the locking mechanism. Can't be bothered replacing the wiper motor. Thanks alot for the help
« Last Edit: 01 October 2013, 02:46 by ljl1981 »
Offline Luke1981
« Reply #8 on: 04 October 2013, 16:32 »
All fixed, before I started ordering parts from ebay I thought I best check the wires in the rubber hoses, and guess what? the wire was split. Quick repair and job sorted.  :smiley:
  • "1.8T AGU"
« Reply #9 on: 04 October 2013, 21:21 »
:afro: The wires inside the rubber trunking on either side of the hinges at the top of the tailgate i'm guessing a common fault also,happened on my old mk4  :laugh: glad your sorted tho  :smiley: i ordered a new catch and mines all working fine now too :afro:
