Author Topic: Best cabling to buy for stereo set-up  (Read 3067 times)
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« on: 19 August 2005, 16:36 »
Can anyone advice on what is the best speaker to amp cable to buy for my stereo set-up? thanks
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Judderi
Re: Best cabling to buy for stereo set-up
« Reply #1 on: 23 August 2005, 09:10 »
which cable do you mean? The cable from the amp to the speakers or the cable from the stereo to the amp? or even the power cable?
Offline Madone_si
« Reply #2 on: 23 August 2005, 13:26 »
Sub - to Amp
Speakers to Amp
SOLD - BLACK SOY 92
Judderi
« Reply #3 on: 23 August 2005, 13:32 »
Use oxygen free for both mate. Thick stuff for the sub and not so thick stuff for the speakers. Bit vague i know but i cant be bothered to check what the guage size is. Will have a look in a mo. P.S where then scanned pages for the 20V T conversion? Hey hey! I really wanna do the conversion now as i got thrashed by one over the weekend. They dont half bloody shift!
Offline Madone_si
« Reply #4 on: 23 August 2005, 14:56 »
thanks - will email you 20V pages later this evening...
SOLD - BLACK SOY 92
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 23 August 2005, 19:42 »
I'd use
10 gauge for your sub
14 gauge for the other speakers
0 gauge power and earth cables to the amps via a distribution block
remember to earth your battery with 0 gauge too!
Mk4 Golf 150PD
Offline rowlers
  • I'm back - MK7 GTI
« Reply #6 on: 23 August 2005, 21:06 »
same goes for powering a 200 watt amp??
0 guage cable sounds big, how do you run that to your boot???
Offline Dizzie
« Reply #7 on: 23 August 2005, 21:15 »
lol. in the edge down the sill. it does go. if you're only running a little amp go for 8 gauge then. the bigger the better though when it comes to power cable
Mk4 Golf 150PD
Offline rowlers
« Reply #8 on: 23 August 2005, 21:37 »
soory to sound numb but why do you need such a heavy duty cable for an item running 200 watts from 12v? Domestic electricity (eg hoover!) runs at 1000w on 240 volts on smaller diameter cable??
Never mind I've just worked it out! :wink:
A domestic hoover at 1200 watts (240v) draws 5 amps!
a 200 watt amp at only 12volts draw 16 amps, hence the need for bigger cables!!!
No wonder you need bigger batteries and alternators to run everything!!!
Offline Dizzie
« Reply #9 on: 23 August 2005, 22:58 »
lol
I was about to explain that too!
I've run a MTX 1501D amp in my car that requires 0 gauge cable run into it! it says on the instuctions this amp can draw in exess of 150 amps! my alternator is only 120A!
I ran it pretty much flat out all day at a show no trouble running 2 15"ers :D
Mk4 Golf 150PD
