Author Topic: Pulling my hair out now!!!! still wont rev past 4500 rpm  (Read 5538 times)
Offline tweed
Re: Pulling my hair out now!!!! still wont rev past 4500 rpm
« Reply #10 on: 24 September 2013, 08:50 »
noooooo completely standard car  :undecided:
have you done what I said?
Offline mervsnart
« Reply #11 on: 24 September 2013, 18:59 »
yes all lined up, no difference,
VW BUSH
« Reply #12 on: 24 September 2013, 21:49 »
have you checked the timing mark on the fly?
Offline mervsnart
« Reply #13 on: 24 September 2013, 22:21 »
tell me more??!! :huh:
Offline tweed
« Reply #14 on: 24 September 2013, 23:07 »
if you done what I said then it will line up.
By the way how did you get number 1 piston to tdc?
VW BUSH
« Reply #15 on: 24 September 2013, 23:36 »
Timing from bottom pulley can be a bit iffy its got a shty mark on it and it's hard to line it up without looking from the wheel arch.
You can double check with a strobe nice an easy.
99% of the time its timing giving this kind of problem the rest of the time it's the sensor
Offline tweed
« Reply #16 on: 25 September 2013, 07:38 »
Yeah sounds like timing to me still
Offline mervsnart
« Reply #17 on: 25 September 2013, 08:46 »
so rather than timing it up via crank marks, I can use flywheel marks? if so what marks am I looking for on the flywheel?
Offline mervsnart
« Reply #18 on: 25 September 2013, 08:48 »
would stored fault codes affect it, or abs light on?
Offline tweed
« Reply #19 on: 25 September 2013, 09:06 »
it really doesnt matter. If you get number 1 cylinder to tdc the timing marks on crank and fly will line up.
Hench why I asked how you got it to tdc?
