Author Topic: Pulling my hair out now!!!! still wont rev past 4500 rpm  (Read 5565 times)
Offline mervsnart
Re: Pulling my hair out now!!!! still wont rev past 4500 rpm
« Reply #20 on: 25 September 2013, 09:33 »
timing mark on crank pulley against mark on aux shaft, and screwdriver down no.1 plug hole
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #21 on: 25 September 2013, 11:22 »
If its all timed up correctly at tdc and your rotor arm lines up with the mark on the distributor then you are timed correctly and more than likely the wiring to hall sensor or the sensor itself. You can check them with a meter although I can't remember the values. Abs light wont interfere.
Offline tweed
« Reply #22 on: 25 September 2013, 12:52 »
Im asking how you got it to tdc?
Offline mervsnart
« Reply #23 on: 25 September 2013, 23:11 »
by turning the crankshaft in a clockwise manner
Offline mervsnart
« Reply #24 on: 28 September 2013, 17:13 »
Sorted it  :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:......coil pack was the problem.
Thanks to all you guys with your help and suggestions, you've been brilliant!!!!! :smiley: :smiley: :smiley: :smiley: :smiley: :smiley:
