Author Topic: Pulling my hair out now!!!! still wont rev past 4500 rpm  (Read 5537 times)
Offline mervsnart
 Hi guys sorry if im a pain :lipsrsealed: got a mk3 gti with an agg engine (8v). it will not rev past 4500 rpm, had a new dizzy and hall sensor, crank sensor, cleaned throttle body, new cam belt timed spot on!! fault code 00515 wont clear but think that's down to a faulty code reader, as it wont clear others stored.
Don't know if this helps, before I refitted the alternator drive belt I ran the car and it wouldn't rev past 3,000.
Any clue where I go next, airflow meter? lambda sensor?
Any help would be greatfully appretiated
                 1997
Car details, mk3 golf gti 8v 2.0
                  agg1633490 engine
Thanx in advance
Offline mervsnart
Re: Pulling my hair out now!!!! still wont rev past 4500 rpm
« Reply #1 on: 21 September 2013, 16:40 »
just a thought ABS light is on :laugh:
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 21 September 2013, 16:42 »
wiring to hall sender or timing are my bet
(the 00515 would say it's hall sender related and cracked/old wiring will make this code stay, the wiring gets brittle over the years and creates issues like you have)
you either needs to buy that part of the loom or make you own, which is quite easy to do
Offline mervsnart
« Reply #3 on: 21 September 2013, 16:49 »
when you say timing, do you a tooth out? made sure that is all spot on
will cut back the wiring to the sensor, how far back do you suggest?
wheres the ecu on these? could the ecu been damage thru jump starting?
cheers buddy
VW BUSH
« Reply #4 on: 21 September 2013, 19:35 »
Dizzy timing could be out, does it line up to the mark at C1 tdc?
Offline tweed
« Reply #5 on: 21 September 2013, 21:05 »
Do it manually.
Get piston in cylinder 1 to tdc (top dead centre) then see if cam pully lines up with the markings.
Then take dissy cap off and get the dissy bang in the middle of the cylinder one firing points.
Offline Ben@VWH
« Reply #6 on: 23 September 2013, 12:18 »
Log the hall sensor with vcds in measuring blocks. It will give you the specification of where it needs to be and its current reading. From memory the hall sesnor needs to be reading between 358' and 3' to function correctly, adjust the distributor until the appropriate figure is seen.
Offline tweed
« Reply #7 on: 23 September 2013, 17:08 »
Oh I mean take spark plug out and put a long screw driver down the bore and feel for tdc.
Offline CJA321
« Reply #8 on: 23 September 2013, 22:46 »
You dont have VR6 clocks fitted for any reason do you?
Offline mervsnart
« Reply #9 on: 24 September 2013, 08:45 »
noooooo completely standard car  :undecided:
