Author Topic: Any tips for fitting k03s oversize tip?  (Read 8191 times)
Offline Chris#101
« on: 19 September 2013, 19:37 »
As above got myself some goodies from r-tech :cool:
Any tips would be much appreciated?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Scott D
Re: Any tips for fitting k03s oversize tip?
« Reply #1 on: 20 September 2013, 02:10 »
try and bend the hard water pipe to make clearance, another pair of hands and a few plasters  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Jin_C
« Reply #2 on: 20 September 2013, 09:39 »
Remember that slicing the end off the turbo side is an option to allow you to fit it on. But try your best without and make sure that is definitely going to work because you don't want to go and cut too much off and junk the TIP. Make sure you dont cut too much off as you need space for the jubilee clip.
Also slide the jubilee on before fitting the TIP!
Oh and say goodbye to your knuckles.
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline Ben@VWH
« Reply #3 on: 20 September 2013, 10:44 »
There is an 8mm allen key bolt that secure the hard metal water pipe to the block, remove this bolt and ease the pipe away from the engine slightly, fit the tip then put the bolt back in with a thick washer between he water pipe and block.  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 20 September 2013, 13:18 »
Chris can you PM me with the price you paid please :wink:
Offline baxxy
« Reply #5 on: 20 September 2013, 22:10 »
Did you fit your tip mate i got mine in the post yesterday looks a very tight fit  :whistle:
Offline Chris#101
« Reply #6 on: 21 September 2013, 17:47 »
Pmd bud  :cool:
« Last Edit: 21 September 2013, 17:58 by Chris#101 »
Offline Chris#101
« Reply #7 on: 21 September 2013, 17:58 »
Fitted it today bud  :smiley:. I was very much thinking the same but I can't see what the fuss is about fitting them :grin: .  Admittedly I was lucky enough to have access to a set of ramps. It took me 1 1/2 hours on my own. I managed to bend the water pipe with it still attached to the block just enough to push the tip down to the turbo inlet  :smiley:
Because Racecar  :cool:
Offline tg1
« Reply #8 on: 21 September 2013, 21:25 »
tbh with ramps it wouldnt be anywhere as near as hard, on the floor/axle stands = no fun.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 22 September 2013, 10:00 »
Do these allow you to fit the DV and hockey puck either way round or just the AUM/AUQ way?
