Author Topic: Any tips for fitting k03s oversize tip?  (Read 8190 times)
Offline Chris#101
Re: Any tips for fitting k03s oversize tip?
« Reply #10 on: 22 September 2013, 12:46 »
Do these allow you to fit the DV and hockey puck either way round or just the AUM/AUQ way?
Erm didn't really experiment tbh. Although there is clearly a bigger and smaller hole I can't remember what's bigger dv or hockey puck!? But the bigger hole is closer to maf end and the smaller hole is closer to turbo  :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 22 September 2013, 13:07 »
Damn that's the opposite way to the AGU...
Offline Screech16v
  • MK3 20vt AGU
« Reply #12 on: 22 September 2013, 15:49 »
tbh with ramps it wouldnt be anywhere as near as hard, on the floor/axle stands = no fun.
I did mine all from the top in about an hour/half,my tip was second hand and had been cut short already so was a bugger to stop it sliding off when tightening the jubilee ,I found the dv and hockey puk had to change places so the pipes were at a stretch to reach there new location,but glad I did it as its made such a difference.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 22 September 2013, 15:51 »
ah but was yours the supersize version...
Offline Screech16v
  • MK3 20vt AGU
« Reply #14 on: 22 September 2013, 15:56 »
