Author Topic: What have you done to your MK 7 today ?  (Read 4885664 times)
Offline P6GTD
« Reply #13870 on: 22 July 2025, 22:41 »
Thanks for reply.
Offline je5343
« Reply #13871 on: 23 July 2025, 22:50 »
Finally got around to adding in a driver's side auxiliary radiator on the CS.
I did some data logging beforehand to do comparison and see what difference it actually makes.
It's a fairly easy install, just 2 connectors (one on the thermostat housing and the other on the main radiator outlet) and a few hoses. All OEM stuff from a Golf R, might do a full write up with part numbers in the future.
No leaks so far just one nightmare of an airlock but that's tomorrow's job!
Offline rowlers
  • I'm back - MK7 GTI
« Reply #13872 on: 24 July 2025, 20:48 »
great idea!
Offline EB2019
« Reply #13873 on: 25 July 2025, 20:53 »
well done, looks tidy in the entire area too!, Without mass of leaves bugs and rust!
Offline A-Kai
« Reply #13874 on: 28 July 2025, 19:25 »
Unnecessary? Yes. Do I like having them? Also yes. Had some spare time and soldered them on - just wished they were a little brighter. Hoping that someone will release higher quality ones like you get in the new BMWs or Audis.
Offline ProtoCulture
« Reply #13875 on: 06 August 2025, 22:00 »
Ohh I like them, details?
Track day at Anglesey last week, car was faultless, love this thing....
2016 Tornado Red GTI PP, DSG, Pro Nav, Dynaudio, Park Assist & Camera.
Mods: Revo Stage 1 ECU & TCU remap. Racingline R600 with Inlet pipe, turbo elbow and muffler delete. Clubsport S backbox. Eibach lowering springs. VBT Hooked discs and Racingline RP700 pads, braided lines and RBF660 fluid.
Protrack One wheels (18x8, ET45) 12mm spacer on rear.
Geo by Swift Performance
Offline A-Kai
« Reply #13876 on: 06 August 2025, 22:50 »
Got mine from this website here: https://auto-passion.co.uk/Volkswagen-Golf-GTI-Door-Welcome-Puddle-Lights-p464333759?srsltid=AfmBOorD9ksKj09_s5J1-Z2ZVerbX3bPRdPO9NflGEDzmk33waMDw80Y
They also sell the harness that you need solder on. However, the harness is super short and does require extending or soldering further along main loom so you’re closer to the reflector cutout at the bottom of the door.
That being said, I’m 95% certain that both the projector and wiring loom are the same ones you can get from AliExpress. They aren’t that bright but work well enough at night.
Offline BKMacC
« Reply #13877 on: 07 August 2025, 18:04 »
You can also get the puddle lights and harness here. It says their harness plugs straight in.
https://rocketwires.co.uk/online-shop/ols/products/vw-golf-mk7-door-puddle-lighting-kit/v/VW-GLF-MK7-Door-Logo-Kit-2-RED
No idea of the quality.
Offline dfm
« Reply #13878 on: 08 August 2025, 16:23 »
I got my local independent garage to change over damaged driver's side wing mirror. I didn't realise changing this would require clearing error codes. I now feel slightly better that I didn't try changing it myself.
Offline willni
« Reply #13879 on: 08 August 2025, 20:06 »
Will be putting my car back to standard as I'm selling up, so will have a few nice bits to go on the classifieds R600 intake, my BBS CI-R and potentially my remus exhaust.
