Author Topic: What have you done to your MK 7 today ?  (Read 4838104 times)
Offline EB2019
« Reply #12950 on: 15 May 2023, 21:53 »
Nothing much to report after 6 months and 2nd mk7, washed after weeks of neglect and went for a mtb ride
Of all the parts on the car I don't mind, the upsweep red in the headlights was a design too far, but works better on red and white imo.
« Last Edit: 15 May 2023, 22:03 by EB2019 »
Offline Gulfstream11
« Reply #12951 on: 16 May 2023, 08:16 »
Replaced my perished tailgate badge drain tube, the tailgate trims are a bit of a bugger to get off as you think your gonna break something.
Anyway, all done, straightforward enough.
Drain Tube part number - 510 827 861A
Ordered mine, should be here soon. If you were to do this again is there a part of the process you may do differently.? There are 2 bottom panels, left and right. Would you pull these first?
Cheers.
Previous rides..MKIV 1.8T   MKIV PD150  MK5 GTI MK5 edition30 now MK7 GTI PP
Offline Watts
« Reply #12952 on: 16 May 2023, 09:48 »
Cheers.
Checked mine the other day as the one on my MK7 had failed in less time than I've had my 7.5 but it's all good. Feels more robust too, perhaps the part has been improved?
Previously:
Offline madstaff
« Reply #12953 on: 16 May 2023, 16:00 »
Cheers.
Pull off the trim along the top of the rear window first, then pull the 2 sides off starting from the top edge, then the main panel.
They need a good firm pull, the main panel you can remove the rear light access panels and help support the clips in there whilst your pulling.
10 clips on the main panel -
« Last Edit: 16 May 2023, 19:16 by madstaff »
Offline bogwoppit
« Reply #12954 on: 16 May 2023, 17:01 »
Indium grey with the Belvedere wheels looks amazing  :cool:
BMW 128ti - current
Mk 7.5 GTI PP, indium grey, manual - gone
Offline EB2019
« Reply #12955 on: 16 May 2023, 19:04 »
Thanks mate   :wink:
I think its the best combo (for met grey), but will be rolling out my old wheels for winter use and pot hole duty this year.
« Last Edit: 18 May 2023, 14:38 by EB2019 »
« Reply #12956 on: 17 May 2023, 07:59 »
Cheers.
Thanks. Thats a great help.  :smiley:
Offline willni
« Reply #12957 on: 22 May 2023, 14:45 »
Had a hunter 4 wheel alignment today:
Offline EB2019
« Reply #12958 on: 23 May 2023, 09:55 »
Nice tidy alignment, feel any better or just peace of mind that its right?
Offline Paul70
« Reply #12959 on: 23 May 2023, 10:33 »
Did you notice any difference Will? Did you decide the Toe specifications or did they advise? I am amazed at how wide the factory specifications are!
I had my car set up a few weeks ago and I am running 0.1 degree of Toe at the front and 0.12 at the rear, which was his recommended baseline set up. Rear camber is virtually identical to yours at 1.55.
I am curious on the how the dynamics would change if the front and rear Toe was reduced, so hence the above question.
2026 Golf GTI ED50
