Author Topic: What have you done to your MK 7 today ?  (Read 4838335 times)
Offline Gulfstream11
« Reply #12940 on: 11 May 2023, 16:00 »
You’re a closet bowler! Tell the truth. 😂
Jeebus no, I am not at that point in life where I have given up. :grin: :grin:
Changed the drain pipe on the tailgate.
Noticed a lot of damp where the spare fits. Googled it and come up with boot badge drain pipe damaged. Went to look at mine and there is an empty hole. No grommit, nothing.
So I need to do this. Is there a part number you can give me and maybe any tips on doing the job right.
The OEM one is rubbish, I upgraded mine years ago and been perfect since.  https://www.golfgtiforum.co.uk/index.php?topic=277074.30
Cheers. Will head to the internet.
Previous rides..MKIV 1.8T   MKIV PD150  MK5 GTI MK5 edition30 now MK7 GTI PP
Offline sjw
« Reply #12941 on: 11 May 2023, 19:35 »
Got and installed AAWireless, works really well, would recommend
Offline rowlers
  • I'm back - MK7 GTI
« Reply #12942 on: 11 May 2023, 21:46 »
Yeah the OEM one is kinda plasticy, with a rubber grommet on the end. The new one I got was all silicone/rubber.
Offline madstaff
« Reply #12943 on: 12 May 2023, 17:42 »
Thought I'd have a look at mine, seemed to be OK so I thought I'd make sure it was clear by shoving some speaker wire up it..................then the grommet on the end crumbled and fell off!!
New one ordered.
Offline rowlers
« Reply #12944 on: 12 May 2023, 20:57 »
 :grin: :grin: :grin: :grin:
Offline willni
« Reply #12945 on: 13 May 2023, 15:39 »
After 3 weeks and 1,000+ miles, I finally caved and washed the car as I've been too busy ceramic coating other cars to see to my own. The interior can wait for another while...
Offline madstaff
« Reply #12946 on: 15 May 2023, 11:23 »
Replaced my perished tailgate badge drain tube, the tailgate trims are a bit of a bugger to get off as you think your gonna break something.
Anyway, all done, straightforward enough.
Drain Tube part number - 510 827 861A
Offline rowlers
« Reply #12947 on: 15 May 2023, 17:35 »
Had new tyres fitted.
Offline Adam T7
« Reply #12948 on: 15 May 2023, 17:57 »
After reading this I cleaned the drain out and squirted a bit of Liquid Moly Gummi Pfledge up the pipe, tested and water runs freely out, thanks for the post - love this site👍
Offline willni
« Reply #12949 on: 15 May 2023, 20:00 »
Fixed the rear seal on my sunroof, the weather stripping came off in the middle so pushed it back in. May need to revisit it with a bit of glue but will see how it holds up.
