Author Topic: New car detail or DIY  (Read 5076 times)
Offline Misterp
« on: 09 September 2013, 07:41 »
I have has some quotes for a new car detail and tbh they are not bad. I'm a complete newbie when it comes to car detailing. I have been doing some research on what and how etc and I got to thinking that maybe I could do it myself. Obviously not to the same extent as a pro but I have noticed that people on here have.
My clean was going to be along the following lines:
1) Hose car down initially
2) snow foam the car using a karcher foam gun - any good foams you could recommend
3) Hand wash using the two bucket method with lambswool mit and gtechniq g wash
3) Hand dry using microfibre cloths
4) Use Gtechniq C2V3 to seal the entire car and the wheels
5) seal the leathers with gtechniq l1
Is that enough of should I be doing more.
Comments and advice much appreciated.
Thanks
Golf GTD mk7 DSG pearl black - collected 25 September 2013.
Offline Pinky 1959
Re: New car detail or DIY
« Reply #1 on: 09 September 2013, 09:07 »
I would suggest a round of iron X (or similar ) gets rid or iron contaminates  and maybe tardis (great stuff ) and then a go with a clay bar then a polish and then ure  c2v3 .
preparation is the key to a really shiny car .
what car are you getting ?
Read the post in this thread about the wifes (not mine )new polo its got all the above points on .
« Last Edit: 09 September 2013, 09:11 by Pinky 1959 »
Offline RocketRossUK
« Reply #2 on: 09 September 2013, 09:21 »
Thanks
This would be classy as a quick weekend was for me.....
If you are going to do a full detail you need at least 4-8 hours. Thats includes all the tasks you said, plus claybaring, machine cut, machine polish, iron X wheels, seal wheels, coat of sealant, full wax, add touch up paint if needed, wet sand them the day after, tyre sealant, glass polish, full interior vax and clean, wash and seal tail pipes etc....
A detail is everything and more. It has taken me about 6 months to acquire all the products i need.
« Last Edit: 09 September 2013, 11:41 by RocketRossUK »
Offline Misterp
« Reply #3 on: 09 September 2013, 10:07 »
Thanks
If you are details you need at least 4-8 hours. Thats includes all the tasks you said, plus claybaring, machine cut, machine polish, iron X wheels, seal wheels, coat of sealant, full wax, add touch up paint if needed, wet sand them the day after, tyre sealant, glass polish, full interior vax and clean, was and seal tail pipes etc....
Thanks guys for the input. To buy all the product will cost the same price as getting the job done professionally. I may look to get it done by a pro then maintain it myself.
MonkeyP
« Reply #4 on: 09 September 2013, 17:13 »
Is this for a new car?
If you want to keep costs down i would say get a clay bar as this will remove tar just means a bit more kneading. Polishing can be done by hand if you want.
The main thing i would ask is how are you're going to clean your car, as you can get someone to polish you paint and make it near perfect but if you washing technique isn't right then all that work and money will go to waste.
Offline Misterp
« Reply #5 on: 09 September 2013, 18:40 »
It is for my new GTD.
I'd look to maintain it properly using the method I set out initially. I wouldn't use the gtechniq sealant with every wash but I would look to top it up once every couple of months.
MonkeyP
« Reply #6 on: 09 September 2013, 20:29 »
Have you got any pictures of the paint.
personally i wouldnt think that it would be that uch work considering it is a new car.
i would say a clay and a light polish (to get rod of any marring from the claying process) should be enough to sort the paint out before you to apply sealant.
Personally its not that hard to do. the getting started is the hardest part after thats its easy.
Offline Misterp
« Reply #7 on: 09 September 2013, 21:03 »
I haven't had it as yet it's deep pearl black.
MonkeyP
« Reply #8 on: 09 September 2013, 23:08 »
Well if u need a second eye let me know as i am local to u.
