Author Topic: Whys my 300bhp Golf cutting out only on Roundabouts ???  (Read 2926 times)
Offline mattyfairbro240579
  • Nearly There With My 2.1 Stroker Build
Hi there, does anyone have any ideas as to what could be causing this issue
As im going into a big roundabout in 3rd gear and then want to put my foot down on the accelerator the cars cutting out, feels like theres no fuel, and as soon as im back on the straight it runs perfectly
2000 1.8T R Tech remap - 310 bhp/321 lb;ft : Decat, stainless 2.5" exhaust, front mount intercooler, KO4 :  S2000 airfilter, Relentless manifold, Badger5 TIP, Saab red injectors, VR6 MAF housing, Forge 007p & Actuator, JK coilovers, Fully polybushed, Vibra Technics engine mounts, ECS Dogbone Mount, Cupra R fuel pump, TT subframe, Porsche 996 Calipers, HELL Lines, Custom 'J' Hook OE R32 Discs, Quaife ATB LSD,  Spec Stage 3+ Clutch & flywheel, WaterMeth, Rear ARB, AEM Data
Offline golfyste
  • Project track car
Re: Whys my 300bhp Golf cutting out only on Roundabouts ???
« Reply #1 on: 22 July 2013, 07:51 »
Traction control kicking in?.......
Offline dom
  • Back in a Mk4
« Reply #2 on: 22 July 2013, 08:25 »
Scanned for fault codes?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 22 July 2013, 22:26 »
It has no traction control. Matty any idea what fuel pump it's running?
Offline asboGTI
« Reply #4 on: 23 July 2013, 11:16 »
+1 this was gonna be my question
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline ben.banks21
« Reply #5 on: 23 July 2013, 12:07 »
sounds like fuel starvation to me and a swirl pot might be needed, if your hitting a roundabout in 3rd then your odviously hitting it at speed. so the fuel in your tank will be shifting from the side of your pump to the other side. fill your tank full then try it. does it pop and bang when doing it?
« Reply #6 on: 23 July 2013, 13:40 »
Hi there, i no the fuel pump has been uprated but unsure as to which pump it is ???
I tried it with 3/4 of a tank a was still doing it  :undecided:
its 50/50 as to whether it pops and bangs
going to remove the fuel pump over the next few days to check if everything is ok with it
need to sort it cos my mate nearly ran up my arse end the other day not realising that the car had briefly cut out on the roundabout
Offline xtetx
« Reply #7 on: 23 July 2013, 15:15 »
bad times matty! bet you were giving it beans on that MASSIVE Warrington round about haha!
Offline leigh_harty
  • Audi AGU
« Reply #8 on: 23 July 2013, 16:26 »
Skems the place to be for massive roundabouts  :whistle: :grin:
Dont lose your dinosaur!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 23 July 2013, 23:34 »
I'm saying fuel pump is struggling. Not sure what one Toby fitted but it might be worth looking for a Cupra R pump, straight fit with no messing about
