Author Topic: Fitting oem xenon front lights  (Read 3494 times)
Offline pedrod316
« on: 18 July 2013, 17:13 »
Hi all
Probally been asked before! But how much work is there in fitting a set of front genuine xenon lights?
Would like a set with the nice led side lights.
I have a 2010 yr golf gti
Would i need different wiring harnes?
Will i get an error on dash etc?
Basically is it possible for someone with limited skills to do, as dont have any software for removing errors etc.
Any idvice/help much apreciated
Offline The Doc
  • E63s Estate - Vito Sport
Re: Fitting oem xenon front lights
« Reply #1 on: 18 July 2013, 17:21 »
Hi all
LOTS of work
YES
YES
NO
Offline pedrod316
« Reply #2 on: 18 July 2013, 17:49 »
Oh dear
Doesn't sound promising then  :cry:
Offline The Doc
« Reply #3 on: 18 July 2013, 19:00 »
Sorry mate, fitting them is a very involved job to say the least.
Offline mike.
« Reply #4 on: 18 July 2013, 19:03 »
I have done this and as the Doc said, it is a lot of work, in fact I think I would trade the car in for one with Xenons rather than do it again. Really happy with the results but not for the faint hearted.
To do a full OEM setup you need to replace the BCM, half the dash has to come out including the knee airbag. You need a new loom to go from the AFS controller to the Autoleveler, which you have to fit, a new loom from the AFS controller to the CAN controller, this is very tricky to get wires soldered on to as it is way back in the dash and a new loom from the AFS controller to each headlight.
Unless you can source a lot of the parts from Ebay etc then it will work out very expensive as well.
Here is the parts list I used
The hardest part was getting to the CAN controller and getting wires connected to the CANH and CANL pins.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Raffe
« Reply #5 on: 18 July 2013, 19:07 »
Best option is aftermarket lights, but you then run the gauntlet as to their quality.
I made the same mistake as you buying a car with halogens  :cry:
Offline pedrod316
« Reply #6 on: 18 July 2013, 19:27 »
G whizz!!
I thought if I bought genuine vw lights it would almost be a plug & play set up, obviously not!!
well I think that idea is knocked on the head big time.
What about the led rear lights? easier?
Typical car has nearly every other extra on it aswell  :grin:
Offline Poached
« Reply #7 on: 18 July 2013, 20:09 »
That sounds savagely involving.
To OP - Perhaps you will have to stick with uprated bulbs? Or sell up lol.
Offline Raffe
« Reply #8 on: 18 July 2013, 20:29 »
G whizz!!
Rear LEDs is dead easy, just need access to Vagcom to code out the error codes, 2 min job and looks great  :cool:
Offline pedrod316
« Reply #9 on: 18 July 2013, 20:33 »
Cool, Think will go with rear lights instead then, will I still get fault with genuine rear's?
Where do you buy vagcom from and is it straightforward?
