Author Topic: Fitting oem xenon front lights  (Read 3486 times)
Offline Poached
Re: Fitting oem xenon front lights
« Reply #10 on: 18 July 2013, 20:53 »
Cool, Think will go with rear lights instead then, will I still get fault with genuine rear's?
Where do you buy vagcom from and is it straightforward?
I wasn't that fussed about the LED's on the front, I just have Xenons. The rear LED lights would be my choice as they really improve the look of the car and aren't a ball ache like the Xenon retrofit is.
Installation on my 59 plate brought a bulb defect light which I had coded out while my car was in the garage for something else.
http://www.youtube.com/watch?v=OBG8fHfXi5s
VCDS will set you back about £250 including a cable so unless you plan to use it regularly then maybe just take it to a garage or find someone with VCDS on the forum who might do it for a small fee.
You can buy VCDS from Ilexa and some other places on the internet.
Offline pedrod316
« Reply #11 on: 18 July 2013, 21:15 »
Thanks for info
Yeh think will just stick to rear lights, will improve the look a lot.
will just take to local garage and get fault removed ,to much cost just for odd thing I require software for.
Offline Poached
« Reply #12 on: 18 July 2013, 22:21 »
Thanks for info
Take it somewhere where they know VAG coding if you can...an unfamiliar garage may go wut?
