Author Topic: newbie with problems  (Read 4368 times)
Offline greener
« on: 08 July 2013, 22:01 »
Hi there
I bought a mk3 8v and I need some help/ideas.
It ran for a couple of weeks then started cutting out then completely died.
I've changed the distributor,  throttle body, crank sensor, plugs and leads, even tried a different ecu and fusebox in it but it still wont work, it will start then it will rev and dip then cut out .
I really like the car and dont want to get rid, anybody got any suggestions.
Offline gazareth
Re: newbie with problems
« Reply #1 on: 08 July 2013, 22:45 »
hi can you here the fuel pump running when you put ignition on?
Offline greener
« Reply #2 on: 08 July 2013, 22:49 »
Hi
Yeah have good fuel flow
Offline gazareth
« Reply #3 on: 09 July 2013, 00:22 »
could be the cat broken up. does the exhaust note sound any different recently?
Offline greener
« Reply #4 on: 09 July 2013, 06:15 »
Oh rite, yeah did sound a bit different
Offline gazareth
« Reply #5 on: 10 July 2013, 18:18 »
try taking out your lambda probe and start it. does the car idle properly?
Offline greener
« Reply #6 on: 10 July 2013, 19:33 »
It idles for about 30 secs then revs and dips then cuts out
Offline gazareth
« Reply #7 on: 10 July 2013, 22:34 »
do you mean it revs on its own then cuts out?
Offline greener
« Reply #8 on: 11 July 2013, 15:44 »
Yeah it revs by itself then dips then revs then cuts out
Offline gazareth
« Reply #9 on: 11 July 2013, 17:47 »
hi what year is the car? and do you know if its an agg or a 2e engine that's in it?
