New forum members
newbie with problems
Topic: newbie with problems (Read 4385 times)
greener
Re: newbie with problems
Reply #10 on:
11 July 2013, 18:07 »
Hi its an R reg 98, its an agg engine
greener
Reply #11 on:
11 July 2013, 18:09 »
Hi its an R reg 98, agg engine
gazareth
Reply #12 on:
11 July 2013, 18:38 »
ah right. there is quite a few running faults they suffer from. but first thing I would try is removing throttle body and give it a good clean and see if that helps. oh does the car start up straight away after it cuts out???
greener
Reply #13 on:
11 July 2013, 18:40 »
Hi yeah it starts up straight away after, the throttlebody has been replaced and was pretty clean before I installed but I will try that , thanks
gazareth
Reply #14 on:
11 July 2013, 18:47 »
was the throttle body replaced because of this problem? or did problem start after? and do you have to press throttle to restart car?
greener
Reply #15 on:
11 July 2013, 20:48 »
I replaced the throttle body after the problem started , no starts normally aftrwards.
It will idle at the moment for a little, but as soon as u press the accelerator and get to about 2000 revs it cuts and dips
Foreveryoungaus16v
Reply #16 on:
11 July 2013, 20:49 »
You taken it to a trusted garage to have a full service etc
KW V2, TEAM DYNAMICS PRO RACE 1.2, EIBACH ARBS, DS 2500 PADS, BLACK DIAMOND DISCS, LIGHTENED FLYWHEEL, CHIPPED ECU, VIBRA TECHNIC MOUNTS, JETEX DECAT, FULLY POLYBUSHED
163 BHP (TSR POWER RUN)
greener
Reply #17 on:
11 July 2013, 20:52 »
Its been at a garage for the last 2 weeks, they hsve tried finding the fault but now they have given up on it , so now im stuck with no idea
gazareth
Reply #18 on:
11 July 2013, 21:33 »
if you start it and leave it idling. will it stay running until you hit the gas?
greener
Reply #19 on:
11 July 2013, 21:34 »
Yes most of the time
New forum members
