Author Topic: newbie with problems  (Read 4369 times)
Offline gazareth
Re: newbie with problems
« Reply #20 on: 11 July 2013, 21:55 »
well I had a problem with my mk2 a couple months ago. when started from cold it would idle fine for as long as I wanted. but as soon as I hit the throttle it would misfire and cut out. then wouldn't start again for about 15 mins. turned out the pressure relief valve in the oil pump was stuck. was fine at idle when the pump was turning slowly but as soon as it was revved the oil pressure would shoot up and overpressurise the hydraulic lifters and keeping the valves open. so I would get an oil pressure test just to be sure. it may not be your issue but there is a chance.
Offline gazareth
« Reply #21 on: 11 July 2013, 21:58 »
oh have you tried running it with the maf disconnected?
Offline greener
« Reply #22 on: 11 July 2013, 23:41 »
Ok cool,  ive been told that the oil pressure was ok but im thinking about getting another garage to have a look, will ask them to check that, yeah tried with maf disconnected still same problem.
Thanks  :smiley:
Offline greener
« Reply #23 on: 18 July 2013, 07:21 »
Had the valve out cleaned it, still not sorted, got no more ideas apart from scrapping it
Offline gazareth
« Reply #24 on: 18 July 2013, 17:37 »
its been a bit elusive this fault eh. have you tried a different throttle position sensor? also check all your pipes and hoses very carefully for air leaks. and check your wiring to sensors for breaks or corrosion.
