Author Topic: question on foam lance  (Read 8559 times)
Offline candywhite12
« on: 04 July 2013, 09:38 »
guys newbie on foaming here so apologies for my numb question.
to use a foam lance, does one need to have a water pressure system? (which would mean buying the foam lance AND the water pressure system)? Or can one use  a foam lance on its own?  (As you gathered i have neither a foam lance or a pressure system).  Also, do all foam lances fit on all water pressure systems?
ta
Current: GTI 8.5, Moonstone Gray, 5dr, Black Estorils 19''. pan, DCC
Wife's: mk8 TSI 1.5 RL, 5dr atlantic blue, DSG, Norfolk 17", pan s/r, leds
Son's: mk7.5 TSI 1.4 RL, 5dr tornado red, DSG, Singapore 17", pan s/r, leds
Before: mk6 GTI 5dr candy white, DSG, Monza Shadow 18", s/r, bi-Xenons, DCC
Even before that: mk5 GT 5dr tornado red, manual, s/r
Offline Dan J
Re: question on foam lance
« Reply #1 on: 04 July 2013, 09:45 »
Hi
You will need a pressure washer and the snow foam lance kit that has the correct attachment for the machine. There are different attachments for different machines.
« Last Edit: 04 July 2013, 09:47 by Dan J »
« Reply #2 on: 04 July 2013, 09:54 »
Hi
hmm, so it's best if i get both pieces from the same place to make sure they fit.
Would 100 bar be enough for snow foaming a car??
Offline Dan J
« Reply #3 on: 04 July 2013, 10:38 »
Hi
No you need to firstly choose a pressure washer you like, depending on what make and model it is will determine what snow foam attachment you'll need for that particular machine.
For example:
 I own a nilfisk c120 pressure washer
This one http://www.screwfix.com/p/nilfisk-c120-3-6-120bar-pressure-washer-with-trolley-230v/56192
And this is my snow foam lance attachment.
http://www.i4detailing.co.uk/acatalog/HD_Snow_Foam_Kit_Karcher_KEWNA_1.html
Here's all the other options which depend on what machine you have.
http://www.i4detailing.co.uk/acatalog/HD_Snow_Foam_Lance_1L.html
100bar will be ok but your foam won't be as thick due to lower flow rates through the various different machines.
Hope this helps
« Last Edit: 04 July 2013, 10:44 by Dan J »
« Reply #4 on: 04 July 2013, 11:06 »
Hi
For example:
Hope this helps
this helps a lot Dan, many thanks. I hope it's worth the cost
MonkeyP
« Reply #5 on: 04 July 2013, 19:02 »
You do not need a pressure washer as there are attachments for your hose that will produce a foam.
heres one on waxamomo.
« Reply #6 on: 04 July 2013, 19:38 »
mate, is this for real? I hope it is but I read someplace that pressures under 100 bar do not produce satisfactory foam.  How will my hose produce foam then, having substantially lower bar pressure than a water pressure system?
Offline Booth11
« Reply #7 on: 04 July 2013, 20:52 »
I've read that these attachments do not produce as good a foam as a proper lance.  Don't think you can beat the real thing.
Btw, highly recommend Bilt Hamber auto foam.  I recently switched to this and am amazed at the improvement over my previous snow foam shampoo.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Dan J
« Reply #8 on: 04 July 2013, 22:27 »
I've tested the gilmour years ago and they are not good for foaming and they cost more than a normal foam lance attachment for a pressure washer, they are good for a general pre soaking with say tfr or apc,citrus pre wash if you just want to soak the car first to loosen the crap,
If you want thick foam that clings then a pressure washer (with a good flow rate)and a dedicated foam lance is the only way to go.
« Last Edit: 04 July 2013, 22:34 by Dan J »
Offline Mr Blue
« Reply #9 on: 04 July 2013, 23:51 »
hose pipe ones are crap. Snow foam is not that effective on unprotected paint.
