Author Topic: question on foam lance  (Read 8597 times)
Online candywhite12
Re: question on foam lance
« Reply #10 on: 05 July 2013, 09:41 »
hose pipe ones are crap. Snow foam is not that effective on unprotected paint.
my hopes gone up in smoke.  the point was to save some money by not buying the pressure system.  If this foamaster is not that good then ....
Current: GTI 8.5, Moonstone Gray, 5dr, Black Estorils 19''. pan, DCC
Wife's: mk8 TSI 1.5 RL, 5dr atlantic blue, DSG, Norfolk 17", pan s/r, leds
Son's: mk7.5 TSI 1.4 RL, 5dr tornado red, DSG, Singapore 17", pan s/r, leds
Before: mk6 GTI 5dr candy white, DSG, Monza Shadow 18", s/r, bi-Xenons, DCC
Even before that: mk5 GT 5dr tornado red, manual, s/r
Offline Ginge 35Edition
« Reply #11 on: 05 July 2013, 14:33 »
Bear in mind that the snow foam doesn't really need pressure, it needs good coverage. I use the karcher one and although it gets slated, it covers the car in foam, I let it dwell - job done!
Online candywhite12
« Reply #12 on: 05 July 2013, 14:39 »
so if it doesn't need pressure, then the foamaster could do the job?  some clips i've seen on youtube suggest it does not spread foam as widely as a pressure system.  Maybe the foam used??
« Reply #13 on: 05 July 2013, 15:17 »
That's my feeling? If it were me I'd go down the pressure washer route because of its other uses. But if it doesn't suit your budget at the moment go with plan b.
Offline Dan J
« Reply #14 on: 05 July 2013, 15:43 »
As I said in my earlier posts the gilmour is fine for just pre washing with the products I stated, if you've only got a hose then this is better than not having it, you just won't get the thick foam.
Offline Raffe
« Reply #15 on: 28 July 2013, 12:41 »
Hi
You will need a pressure washer and the snow foam lance kit that has the correct attachment for the machine. There are different attachments for different machines.
hmm, so it's best if i get both pieces from the same place to make sure they fit.
Would 100 bar be enough for snow foaming a car??
No you need to firstly choose a pressure washer you like, depending on what make and model it is will determine what snow foam attachment you'll need for that particular machine.
For example:
 I own a nilfisk c120 pressure washer
This one http://www.screwfix.com/p/nilfisk-c120-3-6-120bar-pressure-washer-with-trolley-230v/56192
And this is my snow foam lance attachment.
http://www.i4detailing.co.uk/acatalog/HD_Snow_Foam_Kit_Karcher_KEWNA_1.html
Here's all the other options which depend on what machine you have.
http://www.i4detailing.co.uk/acatalog/HD_Snow_Foam_Lance_1L.html
100bar will be ok but your foam won't be as thick due to lower flow rates through the various different machines.
Hope this helps
Wife is buying me a pressure washer and snow foam lance for birthday, price and yor review look good, anything I need to be wary of?
Offline Booth11
« Reply #16 on: 28 July 2013, 12:50 »
Hi
For example:
Hope this helps
Just be sure to run plain water through lance each time you've finished snow foaming.  This should clear it the lance mechanism of foam residue and keep it running smoothly.  You can dismantle lances for cleaning but it's quite an involved process.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Raffe
« Reply #17 on: 28 July 2013, 12:53 »
Thanks Booth :cool:
Probably stupid question so apologies but this pressure washer would be adequate for domestic duties too, block paved driveway etc?
Offline SI74
« Reply #18 on: 28 July 2013, 21:18 »
yes
Offline Diesel power
« Reply #19 on: 29 September 2013, 13:33 »
Hello Raffe, I've recently purchased a snow foam lance from karcher off eBay to fit my little pressure washer, although it did the job the foam wasn't very thick. So after a few days of thinking about up grading the pressure washer and throwing the snow foam at the auto smart bloke how sold it to me, I went and bought a autobrite foam lance direct from there site. Ooooo my god what a difference the lance is awsome. So just skrimp a bit on the pressure washer but spend the money on the ab lance well worth the penny's.
hope this helps
