Author Topic: Silicone tip "nipple"  (Read 3058 times)
Offline 150+
« on: 27 June 2013, 12:44 »
Just got my silicone tip and noticed while reading thru the guide I found on fitting one that the metal nipple for the vacuum isn't there!! Do indeed it??
It's on a AUM ko3s
jamie16v
Re: Silicone tip "nipple"
« Reply #1 on: 27 June 2013, 15:01 »
where by is it?. if its right by the turbo end it`ll be for the charcoal canister evap pipe. can be blocked off if you do a evap delete.
Offline 150+
« Reply #2 on: 27 June 2013, 15:41 »
Offline rfn_hodgson
« Reply #3 on: 27 June 2013, 15:55 »
this one you mean mate??
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline 150+
« Reply #4 on: 27 June 2013, 16:51 »
 :whistle:
« Last Edit: 27 June 2013, 16:56 by 150+ »
Offline 150+
« Reply #5 on: 27 June 2013, 16:56 »
If the one at the top is just blanked off I can sort that  :smiley: but the one at the bottom, is that just a small piece of tube so that you can put a jubilee clip round the vacuum hose to hold it there???
Offline 150+
« Reply #6 on: 27 June 2013, 16:57 »
Yes mate that's the one
Offline 150+
« Reply #7 on: 27 June 2013, 18:06 »
Anyone  :cool: wanted to fit it tonight, pinched a couple of valves from the spray gun spares box at work I have one that fits the feed at the turbo end so if its just something to hold the vacuum hose to I will crack on with it!!!
Sould I use something to "glue" the valve or just use one that's a nice tight fit???
jamie16v
« Reply #8 on: 27 June 2013, 19:40 »
you can cut a bit of rubber pipe to make a coupler and put a tight fitting bolt into it as a temporary fix  .
then use one of these Silicone Blanking Caps when you get it  :smiley:
Offline 150+
« Reply #9 on: 27 June 2013, 19:53 »
Cheers Jamie
What about the other can I fit a a valve I've pinched from work and how would I make it secure??
