Author Topic: Silicone tip "nipple"  (Read 3067 times)
jamie16v
Re: Silicone tip "nipple"
« Reply #10 on: 27 June 2013, 21:21 »
what other are you on about, what valve too? :undecided:
Offline 150+
« Reply #11 on: 27 June 2013, 21:28 »
[/quote]
This one
Offline 150+
« Reply #12 on: 27 June 2013, 21:30 »
I do t have it!! Can I fit a small piece of "tube"so the vacuum hose has something for the jubilee clip to fix to??
jamie16v
« Reply #13 on: 27 June 2013, 21:31 »
have you delelted your charcoal evap canister?
jamie16v
« Reply #14 on: 27 June 2013, 21:32 »
i used a plastic barbed connector iirc..
Offline 150+
« Reply #15 on: 27 June 2013, 21:35 »
I'm not sure what or where the the charcole canister is lol....so I assume I still have it
jamie16v
« Reply #16 on: 27 June 2013, 21:48 »
lol and you want it fitted tonight?.... :laugh:
it should all be obvous when you take your old one off! youre probably still going to need a barbed coupler though.. 12mm was what i needed for my s3 TIP, 10mm seemed ok in my k03s tip
Offline 150+
« Reply #17 on: 27 June 2013, 22:00 »
I got one already...just couldn't think of the word so kept calling it a valve!! Lol
So I can blank off the one at the air box end and fit the coupler to the turbo end??
Do I have to remove the charcoals canister and is there anything else I have to remove..I thought it was just a straight swap when doing this  :whistle:
jamie16v
« Reply #18 on: 27 June 2013, 22:03 »
it should pretty much be so!
Offline 150+
« Reply #19 on: 27 June 2013, 22:07 »
Ok
I know it late but just to be clear do opt don't I remove the charcoal canister??
Thanks for your time I know there a million and one topics on this
