Author Topic: Stuttering under boost  (Read 1871 times)
Offline dub whore
« on: 16 June 2013, 18:11 »
Hiya need a bit of light shed on this. I'm thinking it may be a boost leak causing this stuttering under hard boost and it chuffs out smoke. Is this possible to be the cause? Going throught the gears no problem it's when I'm sat in a gear plodding along and then when I wanna overtake for example and put my foot down it comes onto boost and just coughs and splutters. I'm sure it's not over boost but can't be 100% sure as I don't have a boost gauge linked up. Anyone have some useful input? Many thanx
jamie16v
Re: Stuttering under boost
« Reply #1 on: 16 June 2013, 18:26 »
m m ma ma maf maybe?
Offline dom
  • Back in a Mk4
« Reply #2 on: 16 June 2013, 19:16 »
As Jamie says it could be the MAF, unplug it and see if the problem improves
Offline james2
  • No scammers please.
« Reply #3 on: 16 June 2013, 19:24 »
Why would it smoke on boost /turbo related ?
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
jamie16v
« Reply #4 on: 16 June 2013, 19:29 »
it could be a number of things, turbo is most likely cause though.
Offline dub whore
« Reply #5 on: 18 June 2013, 17:18 »
It's a new turbo. So unlikely to be that. It's almost like its over fuelling and coughs and splutters.  :huh:
Offline Dalo Harkin
« Reply #6 on: 19 June 2013, 12:33 »
Did you replace the turbo with a like for like as in K03 >K03 or K03s >K03s
If you did and its smoking is it white or blue smoke? blue is oil and white is damaged turbo or coolant
Offline dub whore
« Reply #7 on: 19 June 2013, 18:04 »
Not sure on the colour as its hard to tell when your driving flat out lol. And I went from a ko3s to a ko4 001. The turbo has been fine for the last 4 months. I can't see it being the turbo but I'm open to opinions.
jamie16v
« Reply #8 on: 19 June 2013, 21:09 »
was it a genuine or copy turbo?
Offline dub whore
« Reply #9 on: 05 July 2013, 21:20 »
Copy turbo but I don't think it's that. I've since found I have a dtc 00575
