Author Topic: Stuttering under boost  (Read 1865 times)
Offline mattyfairbro240579
  • Nearly There With My 2.1 Stroker Build
Re: Stuttering under boost
« Reply #10 on: 06 July 2013, 00:23 »
As Jamie says it could be the MAF, unplug it and see if the problem improves
Ive got a similar problem at the mo, so ill give it a try, thanks for the great info lads
2000 1.8T R Tech remap - 310 bhp/321 lb;ft : Decat, stainless 2.5" exhaust, front mount intercooler, KO4 :  S2000 airfilter, Relentless manifold, Badger5 TIP, Saab red injectors, VR6 MAF housing, Forge 007p & Actuator, JK coilovers, Fully polybushed, Vibra Technics engine mounts, ECS Dogbone Mount, Cupra R fuel pump, TT subframe, Porsche 996 Calipers, HELL Lines, Custom 'J' Hook OE R32 Discs, Quaife ATB LSD,  Spec Stage 3+ Clutch & flywheel, WaterMeth, Rear ARB, AEM Data
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 06 July 2013, 11:34 »
bear in mind it will only give you about 100bhp lol
