Author Topic: Annoying rattle from 2.5 to 3.5k rpm  (Read 4691 times)
Offline Callum_K
« on: 06 June 2013, 08:46 »
My 8v GTI has developed a loud and annoying rattle between 2.5 and 3.5k rpm. I've had a listen but can't place where it may be coming from! I have uploaded a vid to photobucket, any suggestions as to where to look?
http://s26.photobucket.com/user/calistheman/media/rattling_zps10ec7c5c.mp4.html
Thanks all!
Offline sharki786
  • GOT BOOST??
Re: Annoying rattle from 2.5 to 3.5k rpm
« Reply #1 on: 06 June 2013, 09:18 »
Most likely going to be an exhaust heatshield. Prob the down pipe shield. People tend to rip them off but they are there for a reason
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 06 June 2013, 13:19 »
put a big jubilee clip round the bottom of the downpipe heat sheild
« Last Edit: 07 June 2013, 18:57 by Screech16v »
Offline vwwvgolf
« Reply #3 on: 06 June 2013, 17:07 »
yeh ill say heat sheild. although mine wasnt the manifold but from there back
jack the car up nice and high and look under it
Offline DCmk3
« Reply #4 on: 06 June 2013, 21:12 »
More than likely the exhaust downpipe heat-shield, I had to rip mine out as it was past salvageable unfortunately..
2014 Mk7 GTI - Littco L500
Offline Callum_K
« Reply #5 on: 07 June 2013, 09:32 »
Okay thanks guys will take a look over the weekend when I get the car back from the garage!
Offline GOLF-MK3-GTI
« Reply #6 on: 07 June 2013, 10:16 »
wht dont you ask the garage ppl to have a look?  :undecided:
Offline g3uvn
« Reply #7 on: 07 June 2013, 17:35 »
Had that on my 8v since I got it, whilst changing the lambda on the ramp noticed the heat shield on the downpipe was loose (as others have said above).
You can put a jubilee around the bottom or if you have access to a welder, just grind it back a bit and weld it in place. Mines all sorted now.
Offline murraymint
« Reply #8 on: 07 June 2013, 17:44 »
45mpg  :shocked: your not driving it right!! Lol
josh
Offline Callum_K
« Reply #9 on: 07 June 2013, 18:49 »
Lol take it easy usually on the drive to work with petrol prices as they are!
