Author Topic: Engine mount question!!  (Read 2422 times)
Offline toby2can
« on: 03 June 2013, 20:09 »
2002 1.8 20v t gti AUM. my question is...... ive got a knock that happens if u brake quite heavily an when u pull away fast from the front end sounds like it coming from the bottom of the turbo area but its hard to put a defo position on it . everything is new on the front end: all wishbone bushes, arb bushes, suspension, top mounts, inner+outer tie rods, dog bone, someone mentioned about the engine mounts an ive just had a quick look around an found that the one under the air box moves alot, if you put a lever bar in it you can pry it back an forth nearly from one side to the other, is this normally if so what else could this noise be?!!!! HELP its driving me up the wall!!!!
2002 Golf Gti AUM
Offline toby2can
Re: Engine mount question!!
« Reply #1 on: 03 June 2013, 21:29 »
come on someone must have an idea
2002 Golf Gti AUM
Offline Granta Gti
« Reply #2 on: 03 June 2013, 21:34 »
How long ago did you go the arm bushes and what sort of mileage is the car on?
Offline golfyste
  • Project track car
« Reply #3 on: 03 June 2013, 21:37 »
Then engine mounts sound knackered  :laugh:
Cheap fix! Get a tube of tiger seal and fill the engines units with the stuff
Should stiffen them up and hopefully get rid of the noise  :cool:
Offline toby2can
« Reply #4 on: 03 June 2013, 21:42 »
done them about 2000 miles ago (6 months ish ago) an its got 82000 on the clock
2002 Golf Gti AUM
Offline toby2can
« Reply #5 on: 03 June 2013, 21:44 »
bit of a bodge but could be worth doing just to see if it is the mount then replace it if so
2002 Golf Gti AUM
Offline golfyste
  • Project track car
« Reply #6 on: 03 June 2013, 21:48 »
If I'm honest it's not a bodge whatsoever if done properly.
Tigerseal used to be the big things for tracks toys before polyurethane became so easily available. You would very often see engine mounts filled to the brims with the stuff.
It's cheap yet very effective.
If you wanted you can buy polyurethane mix in bottle and do the same thing but you might find it abit too harsh and it's a bit more of a effort as you have To mix it etc.
Offline toby2can
« Reply #7 on: 03 June 2013, 21:54 »
ill give it a go tomorrow  :laugh:
2002 Golf Gti AUM
Offline golfyste
  • Project track car
« Reply #8 on: 03 June 2013, 21:55 »
To do it properly you will have to remove the mount but its down to your preference really.
Good luck and keep it updated  :huh:
Offline ReDBull
« Reply #9 on: 03 June 2013, 22:18 »
I've just this weekend had he revised VT engine mounts fitted. Very good mod they've made a hell of a difference.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
