Author Topic: catch tank adapters  (Read 1895 times)
jamie16v
catch tank adapters
« on: 09 May 2013, 14:04 »
I cant remember who was having these made t`was many moons ago. i think it may have been wazzer or Dave-iow.
basically i need adapters for my ebay oil catch tank to bring the unions to golf size (iirc its 19mm)??
any idea`s?
Offline mar_k
Re: catch tank adapters
« Reply #1 on: 09 May 2013, 15:19 »
I wouldn't worry too much about using the 15mm ones that come with the kit as the inside of the
hockey puck is way smaller than 15mm. Using the ones you have won't be restrictive at all.
Offline Jin_C
« Reply #2 on: 10 May 2013, 10:55 »
I agree with mar_k. I was part of the thread you mentioned and did all sorts of research and tried bodging together copper pipes and all sorts for a larger aperture. In the end stuck with the standard and it works well, you wont notice any difference and it still collects the vapours.
I used the 19mm hoses recommended for the full set up. For the connections to the catch can, I cut small lengths of the 15mm hose supplied with the can and coated the outside with glue and slid them inside the 19mm hoses. They fit perfectly and create an air tight seal.
If you do want to try a 19mm adapter, try this http://www.ebay.co.uk/itm/BRASS-Male-BSP-Taper-Hose-Tail-Fitting-Silicone-Fuel-Water-Air-Gas-Pipe-BSP-UK-/271178314986?pt=LH_DefaultDomain_3&var=&hash=item3f237cb4ea
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
jamie16v
« Reply #3 on: 10 May 2013, 11:38 »
i wasnt too concerned about the restriction it was more about the leak issues as this could affect maf readings
they look interesting, and me being a plumber and all that i didnt even think of that..haha... :laugh:
Offline mar_k
« Reply #4 on: 10 May 2013, 17:37 »
I done as above, I sleeved the 19mm hose using the crap hose that came with the can.
Offline mar_k
« Reply #5 on: 10 May 2013, 17:40 »
Also are you sure about it affecting the MAF reading?
Not really sure how it can as some people vent the can to atmosphere which would have the same affect as leak at the can surely?
I may be wrong but its a question.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 10 May 2013, 18:25 »
Not me...
I can remember the thread but not who said it. I know that's not much help lol
jamie16v
« Reply #7 on: 10 May 2013, 18:26 »
pull a pipe off your catch can and see how your engine runs!
if there is a leak between the throttle body and maf it`ll run like a sack of sh!t. people who vent to atmosphere plug the hole in the tip fir de hockey puck :wink:
jamie16v
« Reply #8 on: 10 May 2013, 18:30 »
just been through my pm`s... it was cully who was having them made..lol
Offline mar_k
« Reply #9 on: 10 May 2013, 20:03 »
Will give it a try tomorrow just out of curiosity, lol
I'm sure your right, Just trying to get my head round it.
